Page 1 of 14 12311 ... LastLast
Results 1 to 10 of 138
Thread: 600 rpm slip limit solved!!!! OS 25941752
    Dec 2011
    Cool 600 rpm slip limit solved!!!! OS 25941752
    Hey guys figured I better make my first post here a good one so here it is, after countless nights awake reversing code in the a40 tcu
    I HAVE FOUND AND AM ABLE TO CHANGE THE FACTORY SLIP LIMIT 625rpm!!!,
    her is a log proving I have done this! I would like to test this on a few others so for anyone who wishes for me to change your limit send me a copy of your stock tcu file and i will change it to whatever you like.
    I got a full binary from ross and decompiled with idapro. There is also two more colums in the tcc on ramp rate that arent available in the current
    efilive calz file, this and 900+ rpm slip at lockup in third will break the tires loose!
    2007 Classic CCLB, LBZ - EFIlive, Custom 4 inch downpipe and exhaust, Stock trans with BD tripple disk shimmed relief and modded knockdown valve.
    35/12.50/17 Toyo Open country MT's
    1987 Toyota 4x4 8" lift, 35/13.5/15 Toyo open country's, Trail gear suspension, 22r turbo on Propane @ 20psi boost GT2860RS turbo, V6 R150 Transmission.
    Dec 2011
    here's a pic of my modified Efilive calibration to edit the slip limit and the whole TCC on ramp rate.
    Lifetime Member vortecfcar's Avatar
    Apr 2007
    First of all, congratulations!
    That's a worthy first post if I've ever seen one.
    Did you find this as a simple Hex address or does it require you to patch the O.S. Just curious.
    Ive attached the OS for you to apply the update to, or you can send me the hex adress and ill edit it.
    Either way, welcome to the forum!
    Nick
    ps- Is there a way I can contact you privately? The PM function is not active on your user name.
    Nov 2009
    Default 600 rpm slip limit solved!!!! OS 25941752
    Great work!
    -Kory
    http://www.PPEI.com/
    Nov 2009
    Quote Originally Posted by mitchd View Post
    Heck man if you want just send me that TCU file to Kory@LAtuning.com!
    I will test Monday!
    Thanks,
    Kory
    -Kory
    This is going to be HUGE for the Allison guys...
    Mar 2009
    I see alot fewer lockup boxes being sold. Now if somebody could find the torque converter unlock table at 0% throttle I would be alot happier. Having the converter unlock below 55 anytime I let off the throttle regardless of where I set the unlock table is rather annoying.
    Quote Originally Posted by THEFERMANATOR View Post
    Agreed, but it's a global truck issue. REALLY wish the T42s would have this table in truck OSs, not just car OSs.
    Mar 2009
    I'm running the AL5, not a GM T42 TCM. The ALLISON TCM has ALOT of un-mapped parameters in it.
    I know, Im saying in general it'd be nice if the parameter was available (essentially on ALL PCM/TCMs).
    Ive hear the Allisons have a lot of unmapped params in it, but how much more is really necessary? Not trying to start anything, just honestly curious? Except for this converter slip issue with looser TCs and the TC unlocking on 0% TPS, what else do you want?
  1. 600 rpm slip limit
    By killerbee in forum Allison 5 & 6 Speed
    Last Post: December 2nd, 2012, 07:00 PM
  2. Fuel and RPM limit question...
    Last Post: June 2nd, 2010, 11:56 AM
  3. speed/RPM limit cancel!!
    By A.O.A in forum General (Petrol, Gas, Ethanol)
    Last Post: May 27th, 2009, 05:44 AM
  4. RPM limit
    By IdahoRob in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 7th, 2008, 05:41 PM
  5. High RPM power loss solved
    By PSWired in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: October 16th, 2005, 12:43 PM
