Can anyone help me by telling me step by step instructions for connecting the LM-2 analog cable to plug into the V2 flash/scan. its the 3811 cable.
Thanks in advance.
Thanks in advance.
If you have a V2, you should use serial comms...
see post #3 here: serial-port-cable-that-goes-to-v2
showthread.php?t=8858
showthread.php?t=8115
showthread.php?t=10251 post #2
V2 serial/digital AFR input (LC-1):
showthread.php?t=7532
showthread.php?t=8348
showthread.php?t=9340 post #3
Thanks, I am talking about the actual wiring connectors that plug into the V2, I have the V2 already showing the wideband on the program but need to use the orange plugs and this is what/why I need help to make sure I use the correct wire colors to the correct location on the V2 from the LM-2.
Thanks but I am talking about the LM-2 WB wiring into the connectors that plug into the V2, I have the V2 already showing the wideband on the program but need to use the orange plugs and this is what/why I need help to make sure I use the correct wire colors to the correct location on the V2 from the LM-2.
Hi, welcome to the forum. I would recomend you use the serial port (Looks like a telephone jack) on the v2, not the analog connectors. You might need a different cable for the LM2
E85 is NOT flex fuel.
2003 Chevy S10 4.3L LU3 LS1B Auto
48 LB injectors
Race Proven Motors 2114 intake
T70 turbo.
The LM-2 does not have that cable option that i can see at least.
48 LB injectors
T70 turbo.
do you know who else makes them, He hasnt posted since Dec. 2012, tried his home page and it doesnt open.
can anyone help me with how to make one? I have a friend that could make one if we have the info I however am not the smart.
http://forum.efilive.com/showthread....2-Serial-Cable
Should be all the information your friend will need to make one.
48 LB injectors
T70 turbo.
