Results 1 to 7 of 7
Thread: Can't Find PIDs Selction
    Aug 2012
    Default Can't Find PIDs Selction
    Ok I had to redo all my EFI Live system due to an issue with a beta update. Blacky was nice enough to get me fixed and running again but i had removed all my EFI Live PID's i made and maps. Now when following some of the articles write ups like i have done before i noticed there is a missing part in my PID list.
    Here is the list from the PDF as you can see i highlighted in red the Tuning selection!
    Here you can see my drop down and their is no Tuning selection. I cannot find half of these BEN files for some reason.
    Also you can see i cannot find CALC.SELBEN here below?
Name:	no SelBen.jpg
    I dont know what happened to most of these selections. i am on the current stable release but have gone through all my PID selections multiple times and seem to be missing a lot of these. Thank you guys for the help.
    Aug 2012
    I just tried downloading v7.5 again and also did an update chek and it says up to date and still missing these PID's. Anyone else seeing this issue?
    You will need the calc_pids.txt file from post #1 here: Calc-VET-correcting-MAF-and-calculating-VE-(in-single-log)
    you may need to modify it if you're using FlashScan V1 or your wideband only supports the analog interface (which wideband do you have).
    After you get this all sorted out, save a backup copy of the folder "My Computer\EFILive".
    Is this your calc_pids.txt file, see post #10 here: Having-so-many-problems-with-this-Zone-tuning
    Aug 2012
    Im running Innovate LM2 serial.
    I thought i already saved the calc_pid file but i will check again to see if i didnt actually save it or if its placed somewhere incorrectly.
    Thanks Joe
    Aug 2012
    No i reverted the txt file back from when that was done since i mainly do gen 3 pcms.
    Aug 2012
    Damnit it wasnt in the correct folder. all is working correctly. Thank you Joe!
  1. How To Find OS?
    By WisconsinHick1 in forum Tips and tricks
    Last Post: March 13th, 2014, 10:28 AM
  2. can't find PID's for LC-1 on V2.
    By rumblebox in forum General (Petrol, Gas, Ethanol)
    Last Post: October 16th, 2012, 05:17 PM
  3. Can't find some pids for VET tuning
    By myws6formula in forum Gen III V8 Specific
    Last Post: May 28th, 2012, 03:45 PM
  4. 7.5.1 can not find RR
    By mr.prick in forum RoadRunner Real-Time PCM Emulator
    Last Post: December 29th, 2007, 02:46 AM
  5. Help...can't find value.
    Last Post: June 28th, 2005, 03:34 PM
