Results 1 to 10 of 11
Thread: Water in ECM?
    Dec 2007
    Default Water in ECM?
    Is it possible to get water in the ECM? i washed the engine bay yesterday and now have this list of DTC.
    It will run....poorly and im still able to flash the ECM, i just cant clear these codes.
    I pulled apart every connection i could find under the hood, cleaned it with contact cleaner and hit with the blow-dryer before re-assembly. I also threw a charge on the battery, rechecked the grounds and ran a temporary ground straight to the battery with no avail.
    any thoughts? it looks like its one bundle of sensors that isnt getting full voltage
    06 Laramie 3500 QC SB 4x4 - Full billet Auto by DTT, HE351/S475 twins, EFI live, lots of custom goodies....
    07 6.2L Yukon Denali - CAI, CAT delete, self tuned with EFI Live
    03 Trailblazer 4.2L I6 - CAI, custom exhaust, EFI live
    2010 Laramie 3500 CC LB 4x4 - H&S, DPF delete, waiting for EFI Live.....
    Those ECM's are sealed up really well, I doubt water got in, but I agree it's like you are missing a 5V reference to a bunch of sensors.
    Nov 2010
    Maybe not in the ECM ,but possibly in the harness and shorted a circuit out?
    Les Szmidt
    2007 5.9 Dodge Ram
    EFI Live Cummins BETA Tester
    Silver Bullet Tuning
    silverbullettuning@gmail.com
    www.youtube.com/ljszmidt
    Aug 2011
    Check the ecm harness plugs have seen moisture get in there had that happen to me when pushing thru snow banks andgot the engine conpartment full of snow and ice.
    Tuning by Zack StarLite diesel
    Dec 2007
    ive had the ECM plugs off 3 times now & cleaned and dried each time.
    i pulled out the multimeter and checked the MAP sensor plug as it was one on the list. there was a steady 4.95v on the power wire.
    on the ground however, the resistance would hold at 4.0 ohm then spike up to over 12.0 ohm for a few seconds before returning back down to 4 for some reason. im tempted to jumper in a ground lead direct to that wire and see what happens.
    Dec 2007
    this morning i cleared DTC and it started and ran fine. no more codes but it has a "miss" now and then. There must be a connection im missing, or perhaps a bad wire that didnt like the water.
    this was a good read tho:
    http://articles.mopar1973man.com/3rd...supply-circuit
    Jan 2006
    Open the hood and let the sun beat on it for a day. I agree it is not likely that water got into the ECM.
    Out of curiosity, did you pressure wash it?
    Custom Tuning Services
    Dec 2007
    Quote Originally Posted by killerbee View Post
    i soaked it at the carwash with their "tire & engine" cleaner for about 15min, then stood back and rinsed it keeping the direct spray to a minimum
    Quote Originally Posted by skneeland View Post
    Bad deal, avoid doing this.
    Lifetime Member anarchydiesel's Avatar
    Jun 2011
    More than likely water got into the TIPM.
    Anarchy Diesel Tuning/ Advanced Injection Diesel Technologies
    EFI Live Cummins Beta Tester
    Duramax and Cummins Tuning
    423-506-7427
  1. Whats in the water down under?
    By LORDDiESEL in forum Lounge
    Last Post: September 2nd, 2012, 10:07 AM
  2. Dead Roadrunner, not sure how but water damage.
    By 1998ws6 in forum RoadRunner Real-Time PCM Emulator
    Last Post: January 6th, 2012, 05:11 AM
  3. Failed water pump gaskets
    By joecar in forum Lounge
    Last Post: May 24th, 2010, 05:55 PM
  4. I might mix water with fuel. The ethanol manuall
    By 98 tigershark in forum General (Petrol, Gas, Ethanol)
    Last Post: September 11th, 2009, 04:08 PM
  5. EFI and Meth/Water Injection
    By LBZ in forum General (Diesel)
    Last Post: August 6th, 2007, 11:58 AM
