Its meant to say VZ!!
Does anyone the stock VZ LS1 calibrations they can share with me? Interested to see what the differences are.
Just added these to my tune repository for ya
They are a 1MB PCM and therefore a different OS # so you won't be able "compare" directly with EFILive :(
Andrew
EFILive Crew
Thats great service. Thanks.
They look good - much improved timing.
Do the SS tunes or any of the other LS1 VZ tunes vary from these at all??
These are the only ones I've got sorry so I can't tell ya. Like you say timing table definitely looks better.
Andrew
EFILive Crew
That is excellent, PE is interesting as well as the VE looking more like what I thought it should. Though maybe a little beefy down low.
Looks like the extra size has quite a bit to do with ethanol management.
IFR seems to be more linear as well, values are different too.
Interesting O2 switchpoints..
Spark map has the 4000 rpm dip, which as flyer says is well interesting. I found the same through experience, you have to drop spark at peak TQ.
Very good. Lots of good info in that stock tune.
2014 VF SV LS3 Maloo.
From what I hear the VZ VE table is pretty good, go mafless and it runs pretty close to the AFR's it should.
Perhaps Holden used the BEN factor
The VZ VE table - isnt suitable for a VY is it? Do they have a different TB or MAF size?
Should we drop spark at peak torque or peak g/cylinder? I found out last week my peak torque 5100rpm is a little earlier than my peak g/cylinder 5400rpm??
I will start this in another thread.
Thats interesting. In theory Id have thought peak g/cyl is peak tq, especially if its burning all the fuel optimally. Are you sure your fuel and timing is 100% at peak g/cyl?
