Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Uninstalling and reinstalling FlashScan/AutoCal USB drivers
    Quote Originally Posted by voda1 View Post
    I no longer have that version. Is it available somewhere yet?
    Sorry, my mistake, I meant build 235 (not 135) available here:
    https://www.efilive.com/latest/cat/download-efilive
    Oct 2005
    Adding the Virtual COM Port option won't help. FlashScan does not use that.
    I would recommend updating to the latest version here, except there is a known issue with the latest version that causes the exact problem you are seeing with build 235.
    We are working on it right now, as soon as it is fixed in the latest version, I recommend updating.
    I have found that doing this should allow V1 to work with the V7 software again:
    Uninstall V7
    Uninstall the USB drivers (using CMDUninstallerGUI described in the first post)
    Reboot the machine
    Re-installing V7.5.7.135
    Connect FlashScan and wait for Windows to fail to load the drivers
    Open up the device manager page, locate the FlashScan V1 entry, and re-install/update the drivers
    Browse to the Win-2K drivers and install those (yes, even on Win7 and Win8)
    Followed steps listed above but the FlashScan was immediately recognized when plugged in. Went to the device manager and installed the Win-2K drivers. Everything is working OK now.
    97 Vette 6spd, CamMotion Titan2 LS1 cam, TSP 5.3 StageII heads, Vararam intake, Z06 manifold, ARH headers/cats, Z06 catback, Monster Stage2 clutch, 04 Z06 pcv, new style knock sensor(late98 to 04).
    Using FlashScan V1 with NGK-AFX Wide band
    Jul 2012
    following these steps windows 11 won't recognize the driver in any folder.
    Quote Originally Posted by skirsman View Post
    Have you tried using the EFILive USB Manager program?
    Windows Start Button -> search for USB, right click on EFILive USB Manager and select Run As Administrator.
    Jul 2012
    doing some research just find out that windows 11 is the only one that support M1 chip from Apple. maybe that why the windows won't install any driver. Looked into https://ftdichip.com/drivers/d2xx-drivers/
    still won't like it. Maybe there an specific driver for the M1 chip...my old Mac is OK...I also order a different usb cable WO adaptor.
    Jul 2012
    new try with usb-c cable WO adaptor...no luck...look like I need that specific driver for W11 for M1 chip
    ANY HELP
  1. FlashScan/AutoCal USB Drivers: IMPORTANT INFORMATION
    Last Post: February 2nd, 2016, 05:23 AM
  2. Reinstalling V2 drivers
    By Dave_62 in forum FlashScan V2
    Last Post: March 28th, 2007, 11:16 PM
  3. V1 and V2 same USB drivers?
    Last Post: March 27th, 2007, 06:51 AM
  4. v3 usb drivers
    By ZL1Killa in forum General (Petrol, Gas, Ethanol)
    Last Post: February 15th, 2007, 06:20 PM
  5. USB drivers
    By killerbee in forum General (Petrol, Gas, Ethanol)
    Last Post: August 30th, 2006, 12:28 AM
