Results 1 to 3 of 3
Thread: Oct 21, 2023, V8.3.44 Beta Release
    Default Oct 21, 2023, V8.3.44 Beta Release
    V8.3.44 Public Beta Release
    Be careful when installing the beta software on your production systems. It is possible that the beta test software may fail and your production system may not be recoverable. If you conduct a tuning business, please take the necessary precautions to protect your business. EFILive recommends beta testers use a separate FlashScan V3/V2 device (when installing the latest beta firmware) and only install the EFILive beta software on a separate PC, laptop or virtual machine.
    Full Release Notes:
    Version Numbers:
    After installing this release you should have the following software and firmware versions installed:
    • EFILive V8 software: V8.3.44
    • FlashScan/AutoCal V3 Firmware: V3.00.111
    Download here:
    Known Limitations:
    Limitation #1: When logging DMA PIDs (i.e., PIDs whose names end with "_M" or "_DMA"), if the ignition is switched off for an extended period while data logging but data logging is not terminated, then when the ignition is switched on again the data log automatically continues. However, the DMA PIDs may no longer return valid data.
    Limitation #2: When logging DMA PIDs (i.e., PIDs whose names end with "_M" or "_DMA"), that are specific to a custom operating system such as DSP2 or DSP5 PIDs when running a stock operating system, the values returned by those DMA PIDs will not contain valid information and should be ignored.
    Workaround: Ignore unsupported DMA PIDs.
    Known Issues:
    None.
    Regards,
    The EFILive Team
    Jul 2003
    Need a check codes/clear codes button in the scanner screen
    +1.
  1. Sep 21, 2023, V8.3.43 Beta Release
    Last Post: September 22nd, 2023, 10:55 AM
  2. Jun 17, 2023, V8.3.39 Beta Release
    Last Post: June 16th, 2023, 03:09 PM
  3. Jan 20, 2023, V8.3.33 Beta Release
    Last Post: January 24th, 2023, 04:12 PM
  4. Aug 27, 2022, V8.3.29 Beta Release (Updated Oct 20, 2022)
    Last Post: October 19th, 2022, 05:05 PM
  5. Oct 2017, Release Candidate 4 (AKA Public Release)
    Last Post: October 23rd, 2017, 09:17 AM
