With a COS you have to initially edit all of those to sane values...
they are beyond the limits (i.e. out-of-range) but the tunetool displays the closest limit... you have to set them to sane values, or just inside the range, save file, exit tunetool, restart tunetool, set the ones that should be at the limit to the limit, save file...
you have to fix these:
and also A0012, A0013.Out of Range calibration summary: 02:07:06 pm, Friday Jun 14, 2013
EFILive Custom Calibrations
{A0001} Forced Octane Scaler Percentage, was out of range when loaded.
{A0002} Octane Scaler Limiter, was out of range when loaded.
{A0017} N20 Monitor VE Multiplier Table RPM Enable, was out of range when loaded.
{A0018} N20 Monitor VE Multiplier Table MAP Enable, was out of range when loaded.
{A0007} TPS VE Table, contained one or more out of range values when loaded.
[ don't mess with TPS VE table... this needs your VE table to be already corrected in order to properly work ]
