I also do not have a B3647
99 Hugger Orange Z28 - Crate LS6, Bolt-ons, TSP Long Tubes, Borla/QTP, Ram VDS Sintered Iron, Stage 2 T56, Mcleod Master, MWC 9", Strange Pro HD Aluminum, 4.30s, Spool, BMR Subframes - 11.30 @ 121.65
Calc.MAFT -> this corrects the VE table (and calculates a new MAF table from it);So should i do Calc.MAFT or Calc.VET? Im thinking about doing away with the maf all together.
There is no calc.pe pid on my pids list
I do not have an extra bung for my Wbo2 so the pass side o2 is removed, obviously i cant do a CL datalog that way so is there any other options
Calc.VET -> this corrects the MAF table (and calculates a new VE table from it);
[ can you see the pattern of their naming...? Calc.MAFT -> calculates a new MAF table from corrected VE ]
see post #29 here: Summary-Notes
You want CALC.CL not CALC.PE... see post#1 of the Calc.VET and Calc.MAFT threads ( CALC.PE was renamed to CALC.CL );
if you have a .pdf please discard it and have a read of these threads:
http://forum.efilive.com/showthread....se-of-Calc-VET
http://forum.efilive.com/showthread....in-single-log)
http://forum.efilive.com/showthread....-Summary-Notes
[ don't blindly follow... try to understand what is going on ]
If you can't go CL, then you have to edit calc_pids.txt to make SELBEN use WO2BEN only (you do this by setting the CLC for CALC.CL to "0")...
i.e. replace this:
with this:Code:*CLC-00-032 factor 0 4 .0 "{GM.EQIVRATIO}=1"
that will cause SELBEN to use WO2BEN always.Code:*CLC-00-032 factor 0 4 .0 "0"
It would be well worth your while to get the AFR/lambda from your LM-1 to your V2 in serial/digital form (rather than analog)... if you can swing it.
Ok, i understand. Thank you very much, i will start working on that and connect my wide band back up tomorrow.
so basically all i need is this http://www.radioshack.com/product/in...ductId=3964616 to connect my lm1 and fs2 serial cables together?
Yup...
( and there are cheaper ones than that )
LC-1 and LM-1 are similar:
serial-port-cable-that-goes-to-v2 post #3
i bought the parts from radio shack. ill have to set up the flash scan tomorrow. i was wondering if i can connect the lm1 analog wires to my factory harness so i can use the wbo2 for both.
Also check to see if your LM-1 has a SIGNAL IN serial comms input (it probably does not... I"m not familiar with the LM-1) if it does then you need some terminator here (same as LC-1)...
but I don't recall the LM-1 having a SIGNAL IN.
