I'm currently running COS5 2bar OLSD, but will probably go to the semi-open loop (SOLSD) soon once the VE table is good.
Lets say I have B3647 set to 1.0 in the cruise area, so normally it would be in SOLSD. And I have lean cruise enabled to remove 0.09 from the EQR (gives ~15.6 AFR assuming E10). Once the lean cruise enablers are met, will it completely ignore B3647 and also no longer attempt to use the STFT's for trimming?
