Last year I ran a Mini Max and in the hottest setting the turbo maxed out at 32psi. This was the reading on the Mini Max
This year I change to EFI Live and it also maxes out at 32psi.
I just installed a Fleece 63mm cheata turbo at it also maxes out at 32psi.
I am looking for 42psi and after 3 tuning updates it still sits at 32psi.Danville gave up and says that is all that turbo will make. Brayden from fleece just sent me a tune to see if he can get it up to 42.
I can't help but think the issue is somewhere else!! I Get all of my turbo boost readings from the data port under the dash with the H&S last year and the CTS Insight now. I think it gets its reading from the Map sensor.
If the ecm is not getting the right information it could over boost and damage the engine. I may hook up a manual gage to check it.
Rick Abare
