Results 1 to 10 of 17
Thread: Semi-Open Loop Questions
    Feb 2013
    Default Semi-Open Loop Questions
    So I think I got semi-open loop to work... if the short term fuel trims are anything but zero does this mean it's working? They also go straight to zero once EQR is anything but 1.0.
    Something I'm confused about... So I have B3601 set to 14.17 AFR (assuming E10), and I'm commanding an EQR of 1.0 using the STFT's for trimming... This gives me an average wideband lambda of 1.012. Since my NBO2 sensors are attempting to find stoich, does this mean my fuel's stoich is actually 14.17*1.012=14.34?
    Or what is the significance of lambda not being 1.0 when the STFT's are trimming to stoich?
    Here are the settings I used that are different than stock:
    B3801 Long Term Fuel Trim Correction: Disable
    B4108 STFT Idle Enable: Disable
    B4205 Closed Loop Temp Enable: All maximum (284F)
    B3647 Commanded Fuel vs RPM (Normal): Set to 1.0 in area's where I want semi-open loop, which is every column 90kPa and under
    Does anyone have tips on adjusting the STFT settings to improve their trimming ability? They seem to be working okay, but maybe they can be better?
    My first impression is that I like semi-OL. It helped quite a bit with the light throttle and decel bucking. Everywhere else I haven't noticed a difference.
    Here's a log from today, my first log with semi-OL. And a screenshot of the STFT's cycling.
    2001 Silverado 5.3L ECSB 2WD T56:
    T76 turbo, Meth injection, 72# injectors, 799 heads, 212/212 114LSA cam, Built 4L80E, 3.42's
    EFILive V1 Commercial, COS5 2-bar SOLSD, AEM wideband
    Try setting B3601 to 14.17/1.012 = 14.0
    Feb 2013
    Thanks Joe. Could you explain the logic for doing this?
    My wideband is outputting lambda as a voltage. I use this lambda to calculate AFR: WB_AFR=WB_Lambda*B3601
    So using my previous example, WB_AFR=1.012*14.17=14.34. Since the NBO2's target stoich, does this mean 14.34 is stoich?
    Or is there just a 1.2% error in what the wideband thinks in stoich versus what the NBO2's think is stoich? If this is the case, perhaps adjusting the switchpoints is a fix. Mine are all 450mV at the moment.
    Coincidentally I was dialing in the VE tables in OL commanding an EQR of 0.99, which is a lambda of 1.01, pretty close to what I'm getting now in semi-OL.
    My logic was to try B3601 set to 14.0 and see what thw wideband reports... and then go from there (you may be correct in saying stoich is 14.34, but I just wanted another data point).
    Feb 2013
    Ok I set B3601 to 14.0 and logged again this morning, the average cruise lambda was 1.008. Not sure what to conclude from this if anything?
    Lol...
    Try setting B3601 to 13.9 and see if it is consistent.
    What fuel are you running...? Have you checked its alcohol content (using the cheap $20 test kit)...?
    Feb 2013
    Lol...
    91 pump gas. Have not checked the ethanol content yet, perhaps I should. I'll try a new B3601 on the way home today.
    Perhaps there is just an error between what my wideband and my NBO2's think stoich is. I mean, it's only 0.8-1.2%. I'll log my NBO2's today also.
    Feb 2013
    I bought a testing kit so I'll know for sure what I'm getting out of the pump soon.
    Oct 2006
    I just modify the switch points for the o2 sensors until the trims cycle around stoich.
    The Tremor at AIR
    Feb 2013
    Quote Originally Posted by 5.7ute View Post
    What switchpoints are you running now?
  1. cos3 no semi open loop
    By 64camino in forum Gen III V8 Specific
    Last Post: February 5th, 2010, 02:37 PM
  2. Setting up for semi open loop
    By jfclubby in forum Custom Operating Systems
    Last Post: September 19th, 2008, 02:56 AM
  3. COS5 semi open loop ?
    By RandyWS6 in forum Gen III V8 Specific
    Last Post: April 10th, 2008, 03:38 PM
  4. Semi-Open Loop: what's the fuel economy like?
    By SSbaby in forum General (Petrol, Gas, Ethanol)
    Last Post: October 20th, 2007, 12:28 PM
  5. Using Custom OS for autotuning and Semi open loop questions.
    By Chris81 in forum General (Petrol, Gas, Ethanol)
    Last Post: October 12th, 2005, 10:02 PM
