Hi,
I have been having a problem with a VE SS commodore ute lately. It has a camshaft and all the usual bolt ons installed and is running an E38 ECM.
The issue I have has been with hot starts. Basically, the ute can be sitting and idling for an period of time (warmed up), and as soon as you switch it off, it won't restart. It tries to fire, flares slightly over the 1000rpm as normal and then just stalls. It will continue to do this again and again, and I can't keep it alive with the throttle. If I leave it sit for 5mins, it will start and idle as normal. It seems like a heat soat related issue but I cannot see anywhere in my tune that this would be an issue. The tune is almost identical to another customers ute, which doesn't have the problem.
Has anybody had a drama like this before, or could possibly suggest something to help?
Cheers
