Results 1 to 5 of 5
Thread: Locking a LS1B
    Senior Member J.Abbott's Avatar
    Aug 2010
    Default Locking a LS1B
    Ok, so I have an issue. I have decided to start locking my Calibrations on cars that we are building/packages. So I locked my first PCM today, a LS1B controller and all seemsed to go well. I did see a fault at first saying the key did not take and the PCM would be unlocked at end of the full flash.
    Well the PCM locked just fine and that is the issue. I can't unlock it now, I am using the key I gave it and still no luck. I also tried the $FFFF and alt flash keys checked, no luck at all. Anyone have any ideas?
    Justin
    What V7/V8 build...?
    How did you lock it?
    Did you use the option to lock it during a full flash in V7?
    Did you use the specific lock option in V7.5
    Did you use auto-lock feature in FLashScan standalone flashing mode?
    If you used V7, please locate the appropriate *.blx trace file in the folder:
    \My Documents\EFILive\V7.5\Bug Reports
    and email it to me at paul@efilive.com
    If you used V8, please take a backup of your FlashScan licenses using the V8 option: F7: Licenses -> [Backup] and send me the backup file.
    Regads
    Aug 2010
    With both the newest build and the last build. I thought I had the latest but when I read your post I looked and updated the builds and the bootlogger and firmware. Still same issue.
    Aug 2010
    Paul,
    I emailed you. It was done in a full write using the option in 7.5. Tried to also read in 8 just to see if it would work and it did not.
    Justin.
  1. LS1B swap into Chevy 3100?
    By Wheelz in forum Gen III V8 Specific
    Last Post: May 19th, 2013, 01:16 PM
  2. do you need an LS1B PCM ?
    By Boost in forum Gen III V8 Specific
    Last Post: February 19th, 2013, 10:39 AM
  3. ls1B PID's
    By racerx004 in forum Petrol / Gas
    Last Post: November 13th, 2012, 03:05 PM
  4. CKREF PID For LS1B in v7.5
    By mk13 in forum Gen III V8 Specific
    Last Post: July 10th, 2012, 09:40 PM
  5. Trouble with LS1B reflash
    By jbehe in forum Gen III V8 Specific
    Last Post: July 2nd, 2011, 01:50 PM
