Results 1 to 10 of 19
Thread: 2012 Corvette T43 tune file
    May 2013
    Default 2012 Corvette T43 tune file
    Hi,
    new to the forum. I have fitted a 6ltr & 6L80E from a 2011 SS VE into my Torana and all working fine except the TUTD.
    I have rest the stroke on the shifter and modified the shifter to allow me to select P,R,N,D,M.
    I have added some micro switches to the shifter to activate the TUTD but the OS in my current tune will no operate the TUTD and I have been old I will need a Corvette tune file.
    There is only a 2009 tune in File Depot and if there is someone out there with a 2011 file I would appreciate access.
    I have not done a test Full Flash with the 2009 as I would prefer to keep the latest OS.
    As I am new to EFI live any advise would be appreciated, otherwise I will keep tinkering and fix it when I break it.
    I need TUTD or I will have nothing to do on the 1/4 mile!!!
    Aug 2010
    Do NOT try and flash the 2009 Corvette T43 calibration ... not certain about Holden vehicles ... but in the North American market 2009 T43 and 2011 T43 are different controllers (generally) - and the corresponding calibrations are not interchangeable. Also, highly doubtful that a 2011 ECM OS would communicate properly with a 2009 TCM OS.
    There are Australian based tuners that should be able to enable the TUTD option in your current TCM OS - that would be the best course of action - although there would be a cost associated.
    May 2013
    Thanks Taz,
    I will keep tinkering and will try to contact Joel Prince as he lives in the same town. He has been recommended by a few people.
    I was planning a test and tune night this Friday but will just try it out in auto mode.
    Thanks again
    May 2013
    Taz, if there are tuners who can make it work, are they using EFI live and if so it should be possible for me to do it as well? If I can find where to look.
    If not what would they use to edit my current OS.
    I am no longer using the BCM and was told I would need to Full flash in a Corvette OS to make it work.
    Is there somewhere I can find a 2011 Corvette T43 tune file?
    If so I can run a test Full Flash first.
    Aug 2010
    Quote Originally Posted by 6ltrtorana View Post
    ... if there are tuners who can make it work, are they using EFI live and if so it should be possible for me to do it as well? If I can find where to look. If not what would they use to edit my current OS ...
    For you to do this yourself with EFILive - you would need disassembly / decompiler software, and the knowledge to use it, to track down all of the required parameters and their respective locations within the controller / OS environment. You would then have to write a *.cax file to make these new found parameters editable within the EFILive software.
    Any professional tuner that solely uses EFILive to activate the hardwired TUTD routines in a non-Corvette OS has done this type of R&D - quite a lot of work involved.
    No one is going to share this type of information - as it forms part of their corporate service offering, that cost hard dollars to develop.
    ... I am no longer using the BCM and was told I would need to Full flash in a Corvette OS to make it work ...
    Generally, a Corvette TCM calibration SHOULD work within the same model year - however, communications between a non-Corvette ECM calibration and a Corvette TCM calibration are not always "perfect" - you may encounter some glitches.
    ... Is there somewhere I can find a 2011 Corvette T43 tune file? ...
    If there is not one of these in the Tune Repository, then you will have to find a way to source this yourself.
    May 2013
    Thanks very much for the explanation. I am on a steep learning curve and happy to get some info so I don't start stuffing with things that may have the car in the carport for longer. Looks like I wont make the test n tune this week as I just had the car on stands and ran it through the gears and noticed I have a bent axle. Bloody axle hop.
    I will have a look for a 2011 Corvette tune.
    Thanks again
    Aug 2013
    Quote Originally Posted by Taz View Post
    Hi everyone
    Taz,
    Do u have details of a tuner who can do this software mod?
    Cheers
    Aug 2010
    Quote Originally Posted by Steve cooper View Post
    Hi everyone
    Taz,
    Cheers
    What are you working with, and what do you need ?
    Where are you located ?
    Aug 2013
    Sorry for the vauge post!
    I'm in queensland, Australia.
    I have an identical setup to 6ltrtorana, a 2011 l77/6l80 combo out of a commodore, transplanted into a Nissan patrol.
    Last nite I tried to have a corvette OS flashed into my TCM controller at a holden dealership, but he couldn't even read out my tune with his TIS setup. We have a number of theory's as to why that wont work, mostly related to all the other modules missing like abs, cluster ect.
    If you could put me into contact with someone can modify my tune it would be awesome!!!
    Sorry for the thread hijack 6ltrtorana, but i think this will be relevant to your project.
    I also have a 2011 corvette auto file you can use, but its in the "other" software format. If you want it, I'll email it to u.
    Cheers
    Steve Cooper
    May 2013
    Hi Steve, no worries. I have sent my tune file to someone to modify so I can get tap shift working. I have contacted him to see if I can pass on his email address to you.
    I finally got my shift points at WOT sorted by using a ratio calculator to calculate the speed in each gear at 6500 rpm then setting that as the shift speed. Before that it was hitting the limiter when I went WOT as the speeds were all set up for standard gear ratios and tyre sizes.
    That part is much better now but tap shift is critical for both of us.
    Hope we can get it sorted.
  1. Good tune file for a Stock LS3 with a T43 and standard converter
    By scottcmb in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: November 21st, 2011, 05:58 PM
  2. Stock 2009 C6 T43 tune file for 2.73 diff?
    By DeeCount in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: August 30th, 2011, 12:49 AM
  3. Stock 2009 Corvette T43 .tun with the 24249179 os
    By whypave in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: August 25th, 2011, 03:14 PM
  4. need a tune file for a c5 corvette
    By louis in forum General (Petrol, Gas, Ethanol)
    Last Post: November 1st, 2005, 12:02 PM
