Results 1 to 10 of 13
Thread: adding smoke? help
    Jun 2013
    Default adding smoke? help
    i bought a truck not to long ago, 07 classic LBZ. has DSP5 with tunes in it. i bought the EFI with the truck.
    the 5 positions are
    stock
    cleaned up stock (20hp)
    Tow (50hp)
    100hp street
    150hp race
    i need help adding some smoke. they were tuned to not smoke, like at all, even on the 150hp race at wot hardly a haze. the truck is fast and strong but if someone could help me out to maybe alter the 100hp street to smoke. all i need is a little push in the right direction.
    truck has fully built trans and 20% over injectors.
    any help is greatly appreciated.
    Good luck, a smokey tune is simply not needed, all you need is a light haze to spool the turbo and then there's absolutely no reason (except looks) to do it. Plus you waste fuel, so it costs you more $$ in gas.
    That said, more pw/duration and retard timing. Thats all Ill say.
    Jul 2012
    Quote Originally Posted by snyracing14 View Post
    the 5 positions are
    stock
    Tow (50hp)
    100hp street
    150hp race
    Please don't go down the smoke road. It's not cool. It only draws attention from people who already hate diesels and the EPA.
    All i'll say is good tunes don't smoke.
    14 GMC Sierra
    5.3L CC SB 4x4
    Basic tuning....
    Lifetime Member EagleMark's Avatar
    Dec 2010
    If you must smoke? Get a good cigar!
    Mar 2009
    Be prepared for the flaming as TRUE diesel enthusiast have realized how bad coal rolling is. And smoking diesels is why new diesels now have all of the emissions controls and other BS they have.
    Apr 2008
    get an egt guage if youre going to make it smoke = high egt's
    as said before more fuel, less timing and boost
    stock sucks
    Don't attract EPA toward you.
    Apr 2011
    In addition to the EPA issue, think about where all that soot gets routed. It ALL goes through the turbo. With these VVG turbos, more soot will equal sticky vanes eventually. Combine that with the outrageous EGT's and you have nothing but a recipe for (expensive) trouble.
    Just my .02
    If you desperately want it to smoke, please just do it on the track. Diesels have a bad enough name with your average citizen.
    Matt
    '06LLY, 5" MagnaFlow Turbo-Back Exhaust, EGR Blocker, K&N Filter...
    Mar 2009
    In just for entertainment. It's funny to see guys ask about adding smoke.
    2002 Chevy Duramax with a few supporting mods.
    Dec 2010
    Preety sure if you fill your windshield washer with some lite oil and run the line to a vacuum port you could make a gas motor smoke too?
  1. Smoke or No Smoke w tuning EFILive, MCC etc
    By mega2006 in forum General (Diesel)
    Last Post: November 20th, 2012, 06:59 PM
  2. Questions on adding ETC
    By bvd80 in forum Gen III V8 Specific
    Last Post: March 18th, 2011, 03:36 PM
  3. Adding O2's
    By jsm00z28ss in forum Gen III V8 Specific
    Last Post: December 30th, 2009, 09:34 PM
  4. Adding headers + O2
    By BRD-PREY in forum Gen III V8 Specific
    Last Post: July 28th, 2009, 10:12 AM
  5. Adding fuel
    By Lennart in forum General (Diesel)
    Last Post: January 18th, 2006, 03:43 PM
