You are way over complicating this. The calculator in EFI live lets you set the percentage BTDC for EACH cell in that table. So instead of your excel calculator only letting you define a single percentage that applies to the entire table, you can set your cruise area of the table to ~90% BTDC and your power range at 50% BTDC and blend them together for a nice smooth map.
If you want it to work like the excel book just select every cell in the timing calculator table and set it to 50%
Ahhhhh!! Okay. I feel stupid now. I completely understand now. Thank y'all both very much.
[/SIGPIC]
2005 duramax LLY, 12.75 on stock motor/fuel, 68mm vgt built trans.
Built motor by me, built trans, EFIlive by me, dual fuelers, 80% injectors.
