Results 1 to 10 of 11
Thread: Timing calculator.
    Senior Member Quinton's Avatar
    Apr 2013
    Default Timing calculator.
    Okay I'm clueless to the timing calculator for the cummins tuning in efilive. I've used Josh H's calculator for a duramax and it was easy. How do you set your % BTDC?
    [/SIGPIC]
    2005 duramax LLY, 12.75 on stock motor/fuel, 68mm vgt built trans.
    Built motor by me, built trans, EFIlive by me, dual fuelers, 80% injectors.
    Apr 2013
    Anyone?
    [/SIGPIC]
    Nov 2010
    Are you looking for directions to find it?
    Les Szmidt
    2007 5.9 Dodge Ram
    EFI Live Cummins BETA Tester
    Silver Bullet Tuning
    silverbullettuning@gmail.com
    www.youtube.com/ljszmidt
    Apr 2013
    Quote Originally Posted by 2007 5.9 View Post
    No, I'm talking about the timing calculator in efilive's v7.5 software for dodge. Idk how to use it. I have Josh H's calculator in excel for Duramax's. I don't know how to adjust for say 50% BTDC on the cummins calculator in v7.5.
    [/SIGPIC]
    Nov 2010
    Open it up and input the % you wish in the cells and click apply.
    Les Szmidt
    2007 5.9 Dodge Ram
    Apr 2013
    Isn't that just the lowest % timing set point?
    [/SIGPIC]
    Nov 2010
    The values you put in the cells within the timing calc ARE the %.
    Les Szmidt
    2007 5.9 Dodge Ram
    Apr 2013
    I don't get it. If I want the timing set at 50% before top dead center how do I put that in? This is the calculator I use. All you do is put in your % you want BTDC and minimum timing then you copy and paste your main injection pulse and fuel pressure and it does it for you.
    [/SIGPIC]
    Jul 2012
    Quote Originally Posted by Quinton View Post
    You are way over complicating this. The calculator in EFI live lets you set the percentage BTDC for EACH cell in that table. So instead of your excel calculator only letting you define a single percentage that applies to the entire table, you can set your cruise area of the table to ~90% BTDC and your power range at 50% BTDC and blend them together for a nice smooth map.
    If you want it to work like the excel book just select every cell in the timing calculator table and set it to 50%
    14 GMC Sierra
    5.3L CC SB 4x4
    Basic tuning....
    Apr 2013
    Quote Originally Posted by Wheelz View Post
    Ahhhhh!! Okay. I feel stupid now. I completely understand now. Thank y'all both very much.
    [/SIGPIC]
  1. Timing Calculator
    By xploitdiesel in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: May 12th, 2013, 06:15 PM
  2. Timing Calculator
    By mstordahl in forum Cummins 5.9L
    Last Post: November 1st, 2012, 10:27 AM
  3. Timing Calculator for 6.7
    By Compcowboy in forum Cummins 6.7L
    Last Post: March 27th, 2012, 08:12 PM
