Results 1 to 2 of 2
Thread: need help reconfiguring autocal to LB7
    Jun 2013
    Question need help reconfiguring autocal to LB7
    My brother has an LMM with efi live. He let me borrow his AutoCal to check the balance rates on my injectors on my LB7 because I am pretty sure I have one or more bad ones. I am very new at this and I was told that I have to first reconfigure the AutoCal to my LB7 first. Can someone please walk me through on how to do this? And after that I need help with getting my injector balance rates. And then finally reconfiguring it back to LMM. I would greatly appreciate any help!
    Lifetime Member dansdieselp's Avatar
    Apr 2009
    Default need help reconfiguring autocal to LB7
    No you don't. You'll need to hook it up to your laptop and connect to the truck with the EFILive Scan Tool software and select the balanced for all eight cylinders. You can't read them with the Autocal by itself.
    Dan's Diesel Performance
    www.dansdieselperformance.com
  1. Autocal
    By boogie in forum AutoCal
    Last Post: June 4th, 2012, 11:12 PM
  2. LB7 Autocal DSP Beta??
    By boaty3 in forum Do you want to be a Beta Tester?
    Last Post: March 5th, 2012, 10:10 AM
  3. Autocal and DSP Switching for LB7 Question
    By boaty3 in forum AutoCal
    Last Post: February 8th, 2012, 12:09 PM
  4. 03 LB7 pcm into 01 LB7
    By red12secz28 in forum Duramax LB7
    Last Post: November 19th, 2007, 10:40 AM
  5. Autocal
    By Alvin in forum Lounge
    Last Post: August 1st, 2007, 01:55 PM
