Been having an issue with my spark advance not matching the high-octane table. It's usually 1/2 degree lower, but can sometimes be 1-2 degrees lower without KR and with ASPARK at 100%. I'm not sure what else could be pulling spark. I've looked through all of the spark tables and nothing should be pulling spark. I've had this issue for awhile now with the stock OS and with COS5 I'm running now.
Could someone look through the tune and log and see where it could be pulling spark? I have logged spark pids before and didn't see anything pulling spark.
With COS5, DYNCYLAIR_DMA isn't a valid PID, so is it okay to use DYNCYLAIR instead? It looks like it's linking it automatically to the spark tables even though the column indicates DYNCYLAIR_DMA.
I'm most concerned with timing in boost. I'm trying to keep the tune safe as a turn up the boost to get the boost VE table dialed in. Once it's dialed in then I will add water/meth and raise the timing.
Thanks!
