Can AutoCal do a Full Flash Reprogram on a new/blank T42T43/E38/E67 straight from the dealer or must a V2 be used? Thanks.
Trailblazer "RS" 5.3L 6L80 4x4 & '07 TBSS LS2 6L90 AWD
Autocal or V2 could do the T42 or T43, but both the ECM's need to be done at the dealer because of the secondary CPU contained in the E38/E67's, it's not possible to read that part of the ECM, therefore we can't program it either. GM's TIS2WEB system just downloads all the necessary files off their server and therefore is able to reflash everything.
If you are doing a lot of them then you could always consider a $1K yearly subscription to TIS so you can do the same thing on a bench harness.
awesome...thanks!
Get a DrewTech Mongoose Pro GM II Jesse, mine works really well for bench flashing ECM/TCMs from Tis2Web plus the hardware didnt break the bank.
Having problem. Customer is getting $0281 code for both ECM and TCM. I went into the BBX/BBL and set it to read an E38 and T43, saved and uploaded the files in "AutoCal" format....they are in the module. He is using FULL FULL program as the instructions say. When we plug a regular scanner in it can see the ECM, but of course the TCM is not seen bc its new from GM and not flashed.
This is the second time it's not working and we're burning up money with postage and losing weeks due to this. HELP!!!
If you are getting $0281 when trying to read the ECM, then that probably has nothing to do with a blank TCM. Once you are able to read the ECM (or even just Display DTCs) without getting $0281 (i.e. once comms between AutoCal and the vehicle are working), then try full-flashing the T43.
Things to check:
Make sure the AutoCal is using the latest firmware (V2.07.45). To make sure, the user should download and install the latest V8 software and then run the V8 software and click on [Check Firmware].
If you always get $0280 or $0281 when selecting "Display DTCs", then there is a fault in the CAN comms between AuotCal and the vehicle.
Maybe I missed something in the directions or didn't explain myself clearly. We're not trying to read the ECM/TCM...were trying to (re)program. I insured it had the latest firmware before sending it back (by hitting the update button in Scan V8 and then confirming it with the toolbar icon). Again I insured that it was programmed for an E38/T43. I loaded in the calz, which he can see are in the unit and I told him to do FULL PROGRAM...and that's when we get a problem. Last time before I realized I had to programm the E38/T43 it would go 99% then fail. To test COMM lines we tried the shops scan tool which has no problem finding the ECM and pulling up codes. TCM is of course invisible because it's new and unformatted. The PRNDL works. So we know the comm lines are good.
Not for nothing, but does it matter that this was an AutoCal previous tethered to another V2 and still holding old LS1 tunes in it?
I realize you are trying to program it, I was suggesting to try reading the controller, or even easier try reading DTCs to make sure the comms with AutoCal are working correctly. If you can't read DTC's without getting $0280 or $0281 then there's no hope of reading or flashing a controller.
When I said test comms lines I meant the comms lines between AutoCal and the vehicle. Checking with another scan tool is good, it shows the ECM is functioning but it wont help diagnose any comms problems between AutoCal and the ECM. Since you're getting $0280 (as I understand on both ECM and TCM) then we really need to figure out why. There may be a fault in the OBDII cable between AutoCal and the vehicle's OBDII connector, there may be a fault in AutoCal's CAN system.
So really, the first thing to do is to be absolutely certain that AutoCal can communicate with the CAN bus in the vehicle. You can do that by selecting "Display DTCs". If you get $0280 or $0281 then there is a fault.
Once you have confirmed AutoCal is able to communicate with the CAN bus in the vehicle, then the next step is to try full-flashing the T43.
If the AutoCal has been correctly unlinked (by the tuner that originally linked it) and then re-linked to your FlashScan, then it should be ok. Even if it wasn't linked correctly, you would not be getting $0281 errors, you'd get errors like: $0535 or $0536
You (or the end customer) can clear out any old LS1 tune files using the EFILive Explorer program. You'll find them under the [F3: Data files] tab page in the folder: \EFILive\Tune\...
You (or the end customer) can clear out any old LS1 configuration files using the EFILive Explorer program. You'll find them under the [F9: Config Files] tab page
Gotcha! Thanks...I'll update them tomorrow and update you here.
