Results 1 to 10 of 12
Thread: TC lockup question
    Lifetime Member driver456's Avatar
    Default TC lockup question
    My TC locks up like it should,but when the car seems to warm up it unlocks And locks up when it wants and not when I want it too.It has a mind of its own.It will lock in OD and when I'm cruising along around 60-65 it unlocks and won't lock back up,No matter how much throttle I give it or let off.I tried all kinds of settings.I put a shift kit in,But I don't think that has anything to do with it,Does it?I have the right amount of fluid.Can't figure it out....................Paul
    foff667
    Guest
    running the stock cam?
    Quote Originally Posted by foff667
    No,I have a 598/603 114 Lsa. It worked fine when I had 3.42's and a 2600 stall put in,Over the winter I did H/C,headers & 3.73's.I'll try what Chris81 said.....Thanks..................Paul
    foff667
    Guest
    i just bumped my misfire tables up slightly when i did my heads/cam otherwise it would lock & unlock randomly...worked for me.
    Another method is to set all the misfire tables to 32000. You can then, by trial and error, back the numbers down to a level that works. It may not be necessary to do every table either. I just leave mine at 32000.
    2003 red vert
    Mods:
    LPE 100mm MAF
    RPM Level 6/4L60e trans
    3.42 gears
    Yank SS3600
    1-7/8" AR headers
    Z06 exhaust
    470rwhp 437rwtq
    I did what Chris81 said and it seems to be working fine now.......Thanks guy's.I have to know,What does the misfire tables have to do with the TC? And how did anybody figure that out???????
    I did the same thing and it seems to work fine.
    EFILive newbie
    1999 Camaro SS A4 | LME Forged 347 | Yank SS4000 Stall | 226/234 Cam | Patriot LS6 Style heads 2.055 / 1.57 57cc 11.3 SCR | FLP Long tube headers
    Aug 2005
    I've got a friend's truck with an LS1 swap a higher stall converter that does this as well..
    I've heard to set C5601 (misfire detection) to 1 and it fixes it, although it won't catch a misfire anymore.
    Thats just what i've read, I haven't tryed it on his yet..I need to though.
    1992 Turbo LSX Notchback Mustang 275 radial car - under construction
    2008 Sierra 2500HD Duramax
    This might help you out driver456
    "On automatic transmission equipped vehicles, the torque converter clutch (TCC) will disable whenever a misfire is detected. Disabling the TCC isolates the engine from the rest of the drive line, and minimizes the effect of the drive wheel inputs on the crankshaft rotation.
    When the TCC is disabled as a result of a misfire detection, the TCC will re-enabled after approximately 3200 engine revolutions if no misfire is detected. The TCC remains disabled whenever the misfire is detected, with or without a DTC set. This allows the misfire diagnostic to reevaluate the system."
    ChipsByAl is pretty much correct. The converter is unlocked to isolate the drivetrain from shock. But not just any misfire will unlock the converter or set codes. Every engine has some misfire. That's the reason why the number of misfires within a timeframe is required to sense it as "not normal" misfire. Raising the counts to get beyond what is the new norm is best, since some misfire can still be detected. That's hard to do though.
    2003 red vert
    Mods:
    LPE 100mm MAF
    3.42 gears
    Yank SS3600
    1-7/8" AR headers
    Z06 exhaust
    470rwhp 437rwtq
  1. TCC lockup again
    By DURAtotheMAX in forum Allison 5 & 6 Speed
    Last Post: April 23rd, 2011, 02:21 AM
  2. Lockup at the strip?
    Last Post: December 17th, 2010, 09:59 AM
  3. TCC lockup quicker w/80E
    By nonnieselman in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 11th, 2008, 07:06 AM
  4. Soft lockup
    By jfpilla in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: December 10th, 2007, 12:16 PM
  5. TCC Lockup Issue
    By DrX in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: December 28th, 2006, 06:22 PM
