Results 1 to 7 of 7
Thread: TPS VE for idle fueling ?
    Junior Member 3fingas's Avatar
    Oct 2008
    Default TPS VE for idle fueling ?
    Is it possible to use TPS VE solely for idle fueling? I am having difficulty leaning out my idle cells in the main VE and wanted to try to tune fueling for idle in A0007. Must I populate the entire table for this or just the cells I plan on using within in the set parameters? Best lean idle is at 12.3 on e85.
    All PE is set to lambda 1.01 through 3600/ 0.86 through 8000
    B3647 set to 1.01
    No IAC
    No NB 02's ( LC1's on both banks)
    Idle spark 17-26*
    Cam 250/260 .671"
    Idle VE at 95kpa
    Thanks in advance for any input.
    Oct 2008
    Got it! No worries, Thanks
    You only need to populate TPS VE table only up to the enable threshold.
    BTW: regarding your PE: what happens if you stomp the throttle pedal below 3600 rpm (your engine is going to be too lean).
    Oct 2008
    Hey Joe,
    PE will be tuned before I get into the throttle, just trying to get it to idle so I could drive onto the dyno. LOL Problem was the ground on the map weatherpak pin was bent. Now at 70-75kpa at idle. I was just lucky as the connector was the first thing I went to look at.
    I would like to run solely on A0007 but the entire map table has to be redone. A lot has been modified to the motor and most of the table is fat by 30-40%. So for now I was just trying to use TPSVE for the idle cells. Big cam'd race motors don't like to idle at 600 rpm. LOL
    Yes, that's a pretty big cam 250/260 @ .050"
    what is the LSA and the advance...?
    Oct 2008
    Its on a 114 solid roller 376 LS3, 13:1 w 2 stages of n20 on e85.
  1. SAE TPS and actual TPS opening %?
    By O1Z06 in forum Petrol / Gas
    Last Post: February 2nd, 2011, 04:28 AM
  2. idle timing correction/TPS issues
    By hymey in forum Gen III V8 Specific
    Last Post: February 24th, 2010, 05:09 PM
  3. Alpha N (TPS Load) help... noisy TPS signal?
    By Tomato in forum Gen III V8 Specific
    Last Post: July 4th, 2008, 10:22 PM
  4. Couple of questions, idle TPS % and LC-1
    By Darkness in forum General (Petrol, Gas, Ethanol)
    Last Post: May 27th, 2006, 11:50 AM
  5. VE Multiplier vs. TPS vs. RPM table, with non-linear TPS...
    By SSbaby in forum General (Petrol, Gas, Ethanol)
    Last Post: November 7th, 2005, 11:46 AM
