Results 1 to 5 of 5
Thread: Twin turbo boost problems
    Junior Member 05chevy's Avatar
    Oct 2011
    Default Twin turbo boost problems
    A buddy And I installed a 475 over stock twin setup with 60% nozzles. The truck has plenty of fuel. It will smoke till the turbo really light but will only make 40psi.
    I tried opening the vane position from 35 and 1800 across the board. Thinking the small turbo might be choking the larger turbo out. Didn't really help at all with boost.
    I don't think it would be a fueling issue. All though when after the turbos light and only get 40psi it is smokeless. Could the boost reference table be limiting fuel or could the larger injector nozzles be spraying more fuel then a limiter table calls for and is limiting me on the top end?
    Thanks for any help.
    05 lly 11.69 @ 115mph. stock motor, s475, 40% nozzles, lbz reg
    685hp/1100ftlb
    11 Cruze 1.4L turbo
    Member Motorzane's Avatar
    Jun 2011
    Have you messed with the MAF table. You sensor is now having the air sucked across it from the bigger turbo.
    Lifetime Member Dmaxink's Avatar
    Nov 2009
    The issue is that it will take more fuel to
    Drive the 475... Put around 2300uS in that tune and if the cp3 is healthy you will see close to 50lbs.
    Thanks,
    Kory
    -Kory
    I'm out of ideas? Nah trick... When in doubt, 0xFFFF it out!
    http://www.PPEI.com/
    Oct 2011
    Default Re: Twin turbo boost problems
    Quote Originally Posted by Dmaxink View Post
    Thanks,
    Kory
    I forgot to add that the egts will hit 1400* pretty quick. Will more fuel make this worse or will hit help the big charger light and bring the egts back down?
    685hp/1100ftlb
    11 Cruze 1.4L turbo
    Mar 2013
    Are you reading your boost level from a gauge or on EFILive? If EFILive, the MAP sensor has an upper limit that will only show 40ish psi of actual boost. I have Twins and my gauge shows 50 psi but EFILive always tops out at 52.8 psig Total Turbo Boost -- 52.8 - 11.9 psia (I live at 6000 ft) = 40.9 psig If you're smokeless you should be ok.
  1. Twin Turbo Tuning
    By WisconsinHick1 in forum General (Diesel)
    Last Post: May 12th, 2013, 06:17 PM
  2. Twin Turbo CTS-V help
    By gotabav in forum Gen III V8 Specific
    Last Post: July 24th, 2011, 10:29 PM
  3. Need a Twin Turbo Tune
    By mackattack in forum Duramax LB7
    Last Post: April 20th, 2011, 01:30 AM
  4. twin turbo's
    By limited cv8r in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: July 15th, 2007, 03:22 AM
  5. 02 Vette Twin Turbo
    By lplott in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: August 25th, 2006, 04:17 AM
