Thread: Shift point corrrection
    Sep 2012
    Default Shift point corrrection
    Running 38s on my LLY and want to change shift points to match bigger tires. Efilive's built in shift point correction is working, it brings up a pop up that says access denied? How do I manually adjust shift points?
    Mar 2009
    You don't need to change them. The ALLISON isn't like the GM PCM. It doesn't care what size tires your running or gear ratio. It will shift at the same RPM VS TPS and speed with 38's or 28's. Changing the speedometer settings in the TCM can result in some funky shifts and unpredicteable grade breaking.
    Sep 2012
    Hmmm, yea it still shifts at same rpm but i wanted to change it cause with the big tires it feels a bit lazy at lower rpms. i thought it might help if it downshifted earlier?
    Mar 2009
    You can make changes to it to keep it higher up in the RPM's. Just remember to change both your upshift and downshift tables accordingly or else you will get some very awkward and busy shifts that can lead to trans trouble. I would reccomend flashing in an 01 TCM file and see how it does. you will lose overdrive lockout, but other than that you will be fine.
    The larger tires do require higher rpm shift points, and you can universally scale them up with adjustments to
    {H0137} Vehicle Speed Ratio (going from memory here)
    I have found that to be very effective.
    Custom Tuning Services
    Mar 2009
    I went to 3.42 gears in my BURB which is the equivalent of putting 33" tires on a stock truck, and I lowered my shift points as well as running a tighter converter. Couldn't be happier with it setup this way.
  1. Shift point change fro 6L90
    By 55chevdelray in forum Petrol / Gas
    Last Post: May 20th, 2013, 01:48 PM
  2. shift point for ls6 cam
    By aaronr in forum Gen III V8 Specific
    Last Post: August 16th, 2010, 09:14 AM
  3. trouble with shift point tuning
    By hot-dog in forum Allison 5 & 6 Speed
    Last Post: March 23rd, 2009, 10:13 AM
  4. Shift Point Adjuster not working?
    By Ninety8C5 in forum Gen III V8 Specific
    Last Post: October 16th, 2007, 03:09 PM
  5. 4L60E WOT shift point settings
    By billiardcue in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: May 2nd, 2007, 09:34 AM
