Results 1 to 10 of 18
Thread: Problem with timing on lly
    Apr 2013
    Question Problem with timing on lly
    Hey guys, new to efi, but have been working with a tuner and we are having problems with the timing not advancing past 15-16 degrees even tho the tables for the tunes are commanding much higher advance. Has anyone seen this before and is there anything I can do to fix it? My truck is a 2005 duramax thanks
    Jun 2011
    Default Re: Problem with timing on lly
    Could be lots of things, post tune file and I'll take a look.
    Apr 2013
    I will post the file I have.... Not sure if the tuning is unlocked to view but ill post it as well as some logs.we can get the same tune on a single tune to advance but not when it is In a dsp5 file for some reason. Yes it is on the right tune while logging just to clarify. Ill post them here soon thanks
    Apr 2013
    Here they are, the try 2 log is with the single tune and the timing advances, the july 11 log is with the same tune only in dsp5 format with other tunes and the timing doesn't advance. thanks
    Mar 2009
    Look at table B0992 (Maximum Timing Map, Pilot Off) and B0993 (Maximum Timing Map, Pilot On).
    2002 Chevy Duramax with a few supporting mods.
    Jun 2011
    the tune file is locked. you can email it to me if he doesen't want it posted on an open forum. then ill take a look at it. if not were all just speculating here. pm me for email address if interested.
    Apr 2013
    alright I emailed ya
    Mar 2009
    Quote Originally Posted by WisconsinHick1 View Post
    Tune wasn't locked for me. See the above tables.
    Apr 2013
    How did you view it? I tried and I can't view it
    Jun 2011
    Me either.
  1. 2004.5 LLY can I use 2006 LLY tunes?
    By Badass_chris in forum Duramax LLY
    Last Post: October 22nd, 2012, 04:16 AM
  2. ANOTHER LLY Problem, (cant pull stock file)
    By TRUBBS in forum Duramax LLY
    Last Post: June 3rd, 2012, 02:53 PM
  3. lly tcm change vin problem need help
    By MARC75 in forum Duramax LLY
    Last Post: May 25th, 2009, 11:56 AM
  4. os3 in 02 zo6 timing problem
    By b18cls1 in forum Custom Operating Systems
    Last Post: December 17th, 2007, 03:04 PM
  5. weird timing problem
    Last Post: April 20th, 2007, 09:10 AM
