Results 1 to 5 of 5
Thread: My vehicle file
    Jan 2013
    Default My vehicle file
    Here's my vehicle file for a 1990 ZR-1 Corvette. See post #5
    Jan 2013
    Arrrgh... (pulling out my hair)...
    see post #1 here (start at step 5): Hosting-an-Image
    I tried that already. It won't allow me to load the file (maybe because it's xml), in fact the folder it's in doesn't even appear, but I do have it saved to a folder. So, I just opened the folder on my laptop and copied and pasted the text.
    Quote Originally Posted by vilant View Post
    Try by first adding .txt on the end of the filename, and then upload this.
    Jan 2013
    Opened it in XML editor and did a save as .txt
    Will this work?
    A114 1990 LT5 5_7.txt
    Perfect (now it's all a single piece, easier for everyone to look at/sahre), thanks.
    You can also do this (see the filename has .xml.txt on the end of it, when they see this most people will know to remove the .txt from the filename):
    A114 1990 LT5 5_7.xml.txt
  1. Which file corresponds to my vehicle?
    By WCSting in forum AutoCal
    Last Post: February 21st, 2013, 01:50 AM
  2. Creating new vehicle file
    By vilant in forum EFILive V4
    Last Post: February 18th, 2013, 03:24 PM
  3. Vehicle XML file for 1992 buick lesabre
    By MarkS in forum EFILive V4
    Last Post: February 6th, 2009, 06:01 PM
  4. Vehicle file for 1994 Pontiac Bonneville SSEi
    By kjhansen in forum EFILive V4
    Last Post: October 21st, 2008, 04:52 PM
  5. Need Help W/Other vehicle coverage
    By TFZ_Z06 in forum FlashScan V2
    Last Post: August 3rd, 2008, 06:19 AM
