Results 1 to 4 of 4
Thread: Product recommendation
    Jul 2013
    Default Product recommendation
    Hi, Im new here and a bit confused about all the different products. Im looking for a scanner to read the fault codes from my Jeep Cherokee 1996. Will the EFILive Scan Tool allow me to do that?
    No...
    if it's OBD-II then Chrysler uses ISO 9141-2 serial protocol, if it's OBD-I then it uses proprietary protocol.
    EFILive uses SAE J1850 VPW.
    Jul 2013
    Thanks for the information, I believe its a OBD-II, ..so none of the EFILive scanners will work with this?
    Quote Originally Posted by Eugeno View Post
    No, EFILive's V7.5/V8 software and V1/V2 do not have the ability to communicate with that protocol. Just because something is OBDII doesnt mean that everything can communicate with it (unfortunately, that's why CAN was made the standard in 2006-the protocols are the same across all manufactures [light trucks/cars only]).
    If you're just looking for something to read and clear the fault codes on your Jeep, Id buy a cheap Bluetooth OBDII adapter off eBay for $10-12 and use the free version of Torque (iOS/Android). Can read/clear codes on any OBDII vehicle with it. I have one and it works fine, good for my dad's old Audi.
  1. Wide band recommendation that plugs into V2
    By 68problemchild in forum Conversions / Aftermarket Parts
    Last Post: February 14th, 2011, 12:23 PM
  2. How do I get my product Key
    By wadesns in forum General
    Last Post: September 16th, 2010, 06:54 AM
  3. Did I get the wrong product sent out to me?
    By pauly24 in forum FlashScan V2
    Last Post: June 26th, 2010, 06:34 PM
  4. need recommendation for So Cal tuner
    By thomas walters in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: November 12th, 2007, 03:23 PM
  5. looking for recommendation...
    By thomas walters in forum Custom Operating Systems
    Last Post: October 28th, 2007, 05:13 PM
