Results 1 to 5 of 5
Thread: Efi Live Tuner Not Staying Connected
    Jul 2013
    Default Efi Live Tuner Not Staying Connected
    I am new to EFI Live and downloaded it the other day. After downloading and upgrading to the newest version, including bootblock and firmware, I have errors including, Can't get semaphore for control of EFILive_Hapi, Request was ignored - i.e. reply cmd<>send cmd, and No data received. I have uninstalled 4 times (not kiddin) and reinstalled and retried but the same errors keep happening. Another problem is my usb connection, the frames, being transmitted and received have only matched up twice. And even after they did, I got on scan and tune and the error, (No Device Detected) appears. Plz help. I am trying to get efi live installed on my 2011 2500hd chevrolet 6.0. Help would be GREATLY appreciated.
    Jul 2012
    You might post in the flashscan V2 section of the forum for better help with this. Also be sure to read the thread for the latest release. It mentions similar bugs and might have fixes
    14 GMC Sierra
    5.3L CC SB 4x4
    Basic tuning....
    Jul 2013
    Thanks for the information!
    If/when you get a reply cmd<>send cmd error, could you please open the EFILive Control Panel (i.e. click on the FlashScan icon in the system tray, which is near the clock display in the Windows task bar) and select the [F8: Trace] tab page. Then click on [Save trace] and send the trace file to me at paul@efilive.com
    The semaphore error can be caused by a previous instance of the EFILive_HAPI.exe program (i.e. the EFILive Control Panel) still hanging around and not releasing the semaphore. In that case, make sure ALL EFILive programs are closed, start Windows Task Manager (right click on the task bar and select "Start Task Manager"). Select the [Processes] tab page, find an y processes that start with EFILive_ and select them and click [End Process] to terminate them.
    Jul 2003
    i am having the same issues to.
  1. Replies: 10
    Last Post: December 26th, 2011, 08:44 PM
  2. EFI Tuner shootout for Diesel Power Magazine?
    By LBZoom in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 4th, 2010, 02:08 AM
  3. Tuner not correctly following live scanner data?
    By VTC_WS6 in forum Gen III V8 Specific
    Last Post: June 15th, 2008, 06:30 AM
  4. HP tuner inhanced SD vs efi live.
    By tuff in forum Custom Operating Systems
    Last Post: June 14th, 2006, 04:24 AM
  5. Had hp tuner now want to use efi is this ok?
    By killaz in forum General (Petrol, Gas, Ethanol)
    Last Post: May 24th, 2006, 01:16 PM
