Results 1 to 8 of 8
Thread: lmm dsp 5 turbo vane position not working
    Dec 2005
    Default lmm dsp 5 turbo vane position not working
    I have set every table I can see to say around 45% on dsp number 3 and non dsp to 45 it works great untill 140 degs then goes to 80s.
    It is staying in dsp3 though I turned up the Main injector pulse at a idle it bumps up the idle when it goes to dsp 3 just no turbo vane position control what am i missing ?
    Dec 2005
    oops one more thing it works under 140 degs looked all over for something there also
    Dec 2005
    ok to do a double check i changed the injector timing on the dsp5 position 3 to a higher number then the non dsp and it works right on, the only way i found to control turbo position was though non dsp transiant tabble but then its stuck there doesnt change with any dsp2-5 switches ?
    Dec 2005
    a9202 has a typo one part says its for desired boost pressure other says vane control hmm maybe there was a mess up in the lmm dsp 5 set up configuration when it was built
    Dec 2005
    any one have any ideas works great until 140 degs
    Dec 2005
    figured out the problem after 20 hrs
    Mar 2009
    What was the issue?
    2002 Chevy Duramax with a few supporting mods.
    Senior Member whackem04's Avatar
    Apr 2009
    Yes I am working on one now and would love to learn all new things that go on with these new controllers.
    01 GMC Sierra 1500 SLE 5.3 cam swap
    Tuned by ME (COS 5 - running strong and smooth)
  1. Turbo Vane Target Position Question
    By dieselz28 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 21st, 2010, 12:38 AM
  2. LMM-Turbo Vane Target Position
    Last Post: January 23rd, 2010, 06:31 AM
  3. Too much boost and Turbo Vane "TARGET" Position-LMM
    Last Post: November 5th, 2009, 09:27 AM
  4. Min. turbo vane position?
    By IdahoRob in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: April 9th, 2007, 10:56 PM
