Results 1 to 3 of 3
Thread: COS for 2007 Silverado 12613246
    Jun 2007
    Default COS for 2007 Silverado 12613246
    Any ideas of how to get a COS in this truck. Its a 2 bar turbo deal and I need some of the COS tables to make it all work out correctly.
    The OS is 12613246
    I need some boost tables.
    Can I flash it to be something else and just make it work that way???
    Aug 2010
    That's a 2006 OS ... either way there are no COS beyond the 2005 model year. If you try and flash a 2005 OS into a 2006 or 2007 (Classic) truck - there is a high probability that the throttle won't work.
    Aug 2008
    The throttle will not will. I ran into this on a customers 06 as well with his turbo set up. I ended up take the pedal and tac module from and 04 and flashed in an 04 operating system with the CO3. Worked great!
  1. 2007 COS 2 Bar Turbo Truck
    By Mike@Vengeance in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: June 23rd, 2016, 06:11 PM
  2. 2007 Silverado Classic ETC Issue
    By RdRacerZ28 in forum Gen III V8 Specific
    Last Post: August 24th, 2012, 12:46 PM
  3. 2007 Silverado E38 speed limiter
    By BLK02WS6 in forum E37, E38 & E67 PFI ECM's
    Last Post: August 1st, 2010, 12:47 AM
  4. Replies: 3
    Last Post: July 27th, 2010, 03:57 AM
  5. Late 2007 - Early 2008 Silverado 6.0 SD Tune Question
    By Mike Norris in forum E37, E38 & E67 PFI ECM's
    Last Post: March 9th, 2010, 07:57 PM
