Results 1 to 10 of 10
Thread: Trouble writing vin in tune
    Jan 2012
    Default Trouble writing vin in tune
    I'm trying to flash in a tune and vin is all 0's how do I change it so the PCM contains the proper vin again? I changed it in the "home screen" when you first open the tune and flashed it in, but when I pull the tune back out if just shows all 0's still....
    Thanks for the help.
    Use the scantool to write the VIN... goto the DVT tab.
    Senior Member pdasterly's Avatar
    Oct 2007
    how do you write tcm vin?
    Quote Originally Posted by pdasterly View Post
    Select the TCM instead of the PCM/ECM when connecting to a controller in V7.5 Tune. Open a tune, click Flash->Configure PCM security and connect to the TCM.
    Oct 2007
    does this work with v8 or do I have to install v7.5
    1998 Camaro Z28, forged ls2 sts turbo GtsT76, fmic
    1999 Firebird, forged ls1 procharger p1sc ls9 cam fmic
    1981 El Camino, 5.3 LSX carb, msd 6010
    2011 2SS
    You still have to use V7.5 for the Scan tool and Tune tool currently, you need both V7.5 and V8 installed.
    Oct 2007
    playing around with software i notice that I used three pcm license but tcm says available. Do I have to purchase seperate license for tcm tune?
    2011 2SS
    No, 1 VIN license gives you:
    1 PCM/ECM license
    1 TCM license
    If you only tune PCMs, you will have extra TCM licenses available that you can use on any supported vehicle (i.e. a PCM/ECM license does not have to be used in the same vehicle as a TCM license).
    Oct 2007
    Do I need to use license to change vin in tcm. This is for swap into first gen firebird
    2011 2SS
    Oct 2007
    I was able to change everything. Thanks
    2011 2SS
  1. Critique my tech writing!
    By ls1mike in forum General (Petrol, Gas, Ethanol)
    Last Post: March 4th, 2012, 08:52 AM
  2. Trouble flashing in a tune
    By Chris81 in forum FlashScan V2
    Last Post: January 4th, 2011, 10:03 AM
  3. Trouble loading DSP5 Tune
    By Dmaxx 02 in forum Duramax LB7
    Last Post: September 14th, 2009, 07:12 PM
  4. message center writing
    By Deereagtech in forum General (Diesel)
    Last Post: June 9th, 2008, 11:05 AM
  5. Vin # in tune does not show the same as my vin...
    By Loudmouth LS1 in forum Gen III V8 Specific
    Last Post: February 11th, 2007, 10:04 AM
