Originally Posted by
Blacky
If the two orange LEDs are flashing then it is not bricked. However, you can't use EFILive Explorer to reprogram a device that is in dead poll. EFILive Explorer requires some higher level functionality from the device which the device cannot provide if it is in dead poll.
When a device is in dead poll, you need to use the EFILive Control Panel to reprogram it. Select: Start->All Programs->EFILive=V8->EFILive Control Panel, then when the FlashScan icon appears in the system tray (in the Windows task bar near the clock), click on the FlashScan icon to display the control panel window and goto the [F6: Firmware] tab page. You shuold be able to update the firmware from there.
