I have a 2004 silverado with a 6.0 and Tick Turbo Stage 2 cam. Runing a COS3 operating system 2 bar. Where do i start to make it idle properly. Fisrt time dealing with DBW.
Ok i figure out idle in park and in gear. Idles good. But when i rev it up in park it has a hard time finding idle and dies. What do i need to adjust to resolve this?
These links may help:
Idle Tuning
showthread.php?4661-Idle-Tuning-Helpful-Info-Inside
showthread.php?14439-Idle-Tips-amp-Tricks
showthread.php?5866-Auto-VE-questions
showthread.php?14153-scan-tool-wont-log-rafig-or-rafpn
showthread.php?14435-Need-help-Can-Start-Car-but-dies-when-I-give-it-any-throttle-before-going-to-CL
showthread.php?7011-ETC-cars-and-IAC-parameters
showthread.php?14544-Working-on-my-idle-tune
showthread.php?14794-Help-with-open-loop-%28cold-start%29-tuning
showthread.php?149-Idle-%28Transition%29-Tuning
Stumble-3-seconds-after-cold-start&p=178921#post178921
Idle-Tips-amp-Tricks:post#46
More Idle Tuning
showthread.php?t=149
showthread.php?t=5866
showthread.php?p=86553 post #17
showthread.php?t=2630
showthread.php?t=473
Throttle Cracker/Follower
showthread.php?t=3568
showthread.php?t=4081
showthread.php?t=5406
showthread.php?t=5940
Thank you Joe, ill rear through them.
For the most part, tuning DBW idle is very much like cable idle - only instead of the tables manipulating the IAC motor, they open the throttle blade. The tables have the same effect though...
GM EFI Tuner
02 WS6 9.41 @ 143 MPH 3675#, drag radials, pump gas, through the mufflers - sold
