Results 1 to 10 of 20
Thread: Defuel issue on 06 5.9L manual
    Sep 2012
    Default Defuel issue on 06 5.9L manual
    Getting random defuels at WOT. Anyone have this problem before? I can post tune to if anyone wants to take a look at it.
    Lifetime Member anarchydiesel's Avatar
    Jun 2011
    What is your rpm limiter set at?
    Anarchy Diesel Tuning/ Advanced Injection Diesel Technologies
    EFI Live Cummins Beta Tester
    Duramax and Cummins Tuning
    423-506-7427
    Sep 2012
    Which limiter? most of them are at 4000
    Thanks,
    Sep 2012
    Another log, truck will run strong then suddenly drop commanded fuel and slowly come back up.
    Jun 2011
    levibencemod1.ctzTry this and see if it helps.
    423-506-7427
    Sep 2012
    Thanks bud, I,ll try this and post results.
    Sep 2012
    Problem solved, it was the boost axis table. Thanks!
    May 2008
    I just had the same issue with an 06 5.9 manual, so what did you actually change to cure this? I can post my tune.
    2015 3500HD crew cab long bed, 6" fabtech, slightly tuned, emissions intact.
    2005 dmax ccsb, EFI live tuned DSP 5 Full built motor, S471 billet single, More better built trans this time. and lots of other things.
    1984 CJ7 powered by a 2000 LS1. 4L60E.
    2012 Jetta TDI 6 speed manual, (yes the dirty the bastard haha)
    2003 Jetta TDI,
    1986 K10 LQ4/4L80E
    Jun 2011
    try making your boost axis table look something like this.Click image for larger version.
    423-506-7427
    May 2008
    2003 Jetta TDI,
    1986 K10 LQ4/4L80E
  1. Manual upshift downshift 1,2,3,4 on 4L60e without manual valve body
    By Test101 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: October 7th, 2013, 08:30 PM
  2. Manual trans smoke issue
    By straight6 in forum Cummins 5.9L
    Last Post: December 9th, 2012, 05:56 AM
  3. defuel tables
    By crash85 in forum Duramax LB7
    Last Post: January 5th, 2012, 01:02 PM
  4. Help with defuel
    By johnj in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 6th, 2011, 04:25 AM
