EFILive is pleased to announce the public beta release of CSP5 and our Enhanced Data Acquisition (EDA) enhancement for 06-07 5.9L Cummins Customers.
CSP5, EFILive's custom operating system for the Cummins CM849 ECM allows customers to switch 'on the fly' between 6 different tunes, all stored in the ECM's flash memory. Five tunes are accessible through CAN bus switching, and a sixth tune can be switched using an input on one of the ECM's connectors.
By having multiple tunes instantly accessible, customers no longer need to re-flash their ECM to change their tunes to suit changing conditions (eg. racing, towing or power limiting). Simply build up your tunes, flash the ECM once and then select your desired tune through your EFILive hardware (or other approved switching devices) at any time.
Enhanced Data Acquisition (EDA), revolutionizes the way customers scan and log data. Exclusive to EFILive, EDA aims to simplify the task of logging by creating a single group of 45 parameters hand selected by tuners as essential tuning feedback items. Some EDA parameters are not even available on the Dealership scan-tool.
With logging speeds of up to 50 frames per second and each frame containing 45 data parameters, this enhancement is the envy of every other Cummins data logging system in existence, including earlier versions of our own software. EDA's speed and data selection is simply unparalleled, with most other scan-tools lucky to get just 15 (not so useful) SAE PID's at 12 frames per second.
A range of security measures have also been added; tunes are automatically locked from being read to stop unauthorised copying, and password protection is available for tune selections. Blackbox logging (BBL) for Cummins completes the updated features for this release.
To access these features, customers must be running July 18, 2013 (or later) V8 and V7.5 software, and update their FlashScan V2/AutoCal firmware.
CSP5 upgrade documentation can be found in the July 18, 2013 (or later) installation by navigating to Program Files>EFILive>V8>Documentation and look for the document 'Cummins 5p9L CSP5 User Guide.pdf'.
EDA scanning is only available on CSP5 upgraded ECM's using FlashScan V2 or AutoCal hardware.
In addition to switching via FlashScan V2 or AutoCal, integration of EFILive's proprietary CSP5 custom operating system with 3rd party products is restricted to approved providers. EFILive recommends that customers confirm that their chosen integration product is approved for use. A list of integrated partner products can be found here
Cheers
Cindy
