Page 3 of 9 FirstFirst 12345 ... LastLast
Results 21 to 30 of 89
Thread: CSP5 and EDA Release for 06-07 Cummins
  1. #21
    From the EFILive Error Codes Document
    Error $0194.....
    Usually this means that the target file system is full.
    If you are programming BBX configuration data, try reformatting the Config file system using the drop down option on the [Program] button. Then [Program] the BBX configuration data again.
    If you are reading or data logging, check that the SD Card (or FlashScan’s/AutoCal’s internal memory) has enough free space.
  2. #22
    Member Motorzane's Avatar
    Jun 2011
    Default CSP5 and EDA Release for 06-07 Cummins
    Error $0194.....
    That fixed it! Thank you very much
  3. #23
    FYI, you can access that reference document from the Windows start menu >> EFILive >> V8 >> Documents >> "EFILive Error Codes", or from within the V8 Scan and Tune Help menu.
  4. #24
    Junior Member jordylee18's Avatar
    Oct 2011
    Default Re: CSP5 and EDA Release for 06-07 Cummins
    I'm having problems upgrading a 2601 OP to CSP. I upgraded one of my 2601 tunes to CSP and then tried to upgrade another 2601 and it says op not supported. It's saved in ctz format. Any ideas?
  5. #25
    Jun 2011
    Quote Originally Posted by jordylee18 View Post
    Was the V2 plugged in when you tried to do the update
  6. #26
    Oct 2011
    Quote Originally Posted by Motorzane View Post
    I tried both ways.
    Heres the tune I want to convert. I got it to work once, cant now.
    [ATTACH]15571[/ATTACH
  7. #27
    The option shows up fine for me with the file above. Only the USB side of the V2 needs to be plugged in before you start V7.5 Tune Tool, doing that should allow the option to show up.
  8. #28
    Aug 2011
    Yes i was scratching head for same thing went back and read v2 plugged in before opening v7.5 tune tool maybe try rebooting computer .
    Tuning by Zack StarLite diesel
  9. #29
    New Member _PSI_'s Avatar
    May 2013
    Will we be able to trigger relays and/or switch tunes based off an ECM value? For example, WOT triggers a relay? I heard something about using the grid heater circuit?
  10. #30
    Lifetime Member comnrailpwr's Avatar
    Jun 2011
    Yes you can enable the 12v grid heater control circuit based off multiple preset values such as rpm, speed and fuel pressure.... grid heater must be disabled to do this tho.
  1. EFILive July 18th Beta Release (CSP5)
    By GMPX in forum Software Updates and Installation Help
    Last Post: August 22nd, 2013, 02:18 AM
  2. CSP5 - Cummins Switchable tuning - it's HERE!
    By cindy@efilive in forum Cummins 5.9L
    Last Post: July 18th, 2013, 07:46 AM
