This is my first post on the forum so I hope I'm not asking too much, could someone send me a hi idle stock tune for 35325553? I loaded a tune that was sent to me on my truck as I couldn't read my stock one kept giving me the $11 error.. hope I didn't mess up doing that before I saved a stock tune! Sure is a steep learning curve gettin setup with efi live but is very hard to stay away from it now. Could someone help me out? the truck is 06
Check with Les to be sure, but I think the file he posted for me will work the same for you. It worked great on mine...
Okay didn't know how different the calibrations are, thanks!
Be sure to change the VIN!!!
I have the same truck, how do I attach the file for you?
To Live, To Serve...
To bring up this old thread, Les is that file one of the good latest OS? Like I see some issues some 2006s had that apparently got fixed through time with new flashes from dealer. Is this a good one?
Sent from my iPhone using Tapatalk
Well I found out the hard way that 2007 file listed above does not run on my 2006. Changed it to match my other OS tune identically and it wont run para chit.
As long as it's the same trans file, any 2006-2007 5.9 file can be used in any cmb849 ecm.
Les Szmidt
2007 5.9 Dodge Ram
EFI Live Cummins BETA Tester
Silver Bullet Tuning
silverbullettuning@gmail.com
www.youtube.com/ljszmidt
Now there are some OS with different scaling, and that's likely your issue.
Les Szmidt
2007 5.9 Dodge Ram
