Results 1 to 3 of 3
Thread: $0311 on 97 S-10
    Lifetime Member LBZoom's Avatar
    Jun 2008
    Default $0311 on 97 S-10
    Hey guys,
    Got a customer with a 97 S-10 truck. We're trying to use his Autocal to upload the tune file so we can work with it. I'm handling this remotely for him.
    Keep getting error $0311 mode not supported, we've updated software a few days ago, re-formatted device etc.... no luck yet.
    Any ideas? Thanks!
    Peace Through Torque
    www.PunisherPerformance.com
    Aug 2010
    The 1996 & 1997 Black Box Vortec PCMs are not supported by EFILive (or HPT).
    You need use TunerCat or Jet DST to modify that controller.
    May 2010
    You did not say if you have a 4.3 or 2.2 truck, or planning a lsx V8 swap I will assume 4.3 ? Common way to get around your problem is to update your ecm to a 0411 ecm, which can be found on just about any 2001-2002 GM V6 vortec engine or ls1 V8/truck ecms vehicles made. A quick internet search will get you going in the right direction. I would guess since you are here you are not interested in a jet dst?.Since you have autocal. You can pm a member lextech for a simple to follow guide(pinout) on how to convert a 97 4.3 truck to a 0411 ecm. If it is a 2.2 ecm it can still be done just not as common as the 4.3.
    1997 S10, 06 trailblazer SS LS2 swap, 4L70E trans, 76mm turbo. Factory ZQ8 suspension. 3.08, G80 w/a zexel. With a 0411 swap.
  1. Reading Error $0311
    By dvst8r in forum Cummins 5.9L
    Last Post: September 4th, 2011, 01:44 PM
  2. $0311...cant clear DTC's on LLY
    By bobo in forum FlashScan V2 BB Logging
    Last Post: January 6th, 2008, 06:58 PM
