Immediately after kickdown the PCM knocks the throttle back down to 20% then lets it go back to 100%. All of this takes place within 1-2 seconds. It must be responding to input from some sensors to trigger this. As it is in OL/SD(no O2s or MAF) it must be related to RPM, MAP or something to do with the trans, right?
FP is steady since I installed the returnless system and the PCM has no input as to what the FP or AFR is anyway. Although AFR does rise during the sudden throttle transition. Misfire logs all show 0 counts.
