Results 1 to 2 of 2
Thread: C&C Tune help please! 6.7 in Ford
    Mar 2013
    Default C&C Tune help please! 6.7 in Ford
    First off I am installing a 6.7 in an 08 Ford. The engine is out of a c&c. I have been able to get it to start and run for about 3 seconds which, after hours of reading and searching, sounds like an issue with either the theft system or the type of ecm itself. The numbers I pulled out of the stock file are...os-11610805 cal.-61301434. I read this thread which sounds exactly like what is happening to me http://forum.efilive.com/showthread....7-After-Smarty. I can't say whether or not this had a smarty installed or not but it is starting and run for a few short seconds and then dying.
    Can you flash different operating and calibrations systems in to try? I may have created my own brick by trying too many different tune files. That or maybe the ecm timed out (if that's something they do). The last couple files I have tried off of tunedepot wouldn't allow it to start at all. Tried putting stock tune back in and still won't start. May give up for the day and hope someone can help.
    Btw this is an 08 ecm on the engine, right now I have all the emissions components on it and I am just trying to get it to start and stay running for the moment.
    Aug 2009
    Quote Originally Posted by 406nick View Post
    make sure you are putting in the correct vin after a flash.
    open scan tool connect to the vehicle and press ctrl+alt+v, enter correct vin.
    sounds similar to what was happening to me.
  1. '02 Z28 & SS - same tune?
    By Boost in forum Gen III V8 Specific
    Last Post: March 10th, 2013, 05:32 AM
  2. 2004 GMC 6.0 4L80E & manual Transfer into 1978 Ford F-100...Trans????'s
    By GAMEOVER in forum Conversions / Aftermarket Parts
    Last Post: April 1st, 2012, 06:16 PM
  3. Replies: 8
    Last Post: February 18th, 2010, 10:30 AM
  4. My log & tune @ track 12.06
    By Ls1_Rulz in forum Gen III V8 Specific
    Last Post: November 3rd, 2008, 09:37 AM
  5. Hi, im new just puchased flash & tune
    By blitzer in forum General (Petrol, Gas, Ethanol)
    Last Post: September 16th, 2005, 04:10 PM
