Results 1 to 10 of 17
Thread: 6.7 Swapped into Ford - SKIM Issue
    Jul 2012
    Default 6.7 Swapped into Ford - SKIM Issue
    I am using the stock tune and O/S that came with this ECU, disabled SKIM and still it dies in 3 seconds and won't start at all after 5 times. From what I understand this is the anti-theft issue, but I just cannot seem to get around it.
    Any ideas anyone?
    2008 6.7 Cummins ECU
    O/S: 11620500
    Cal: 62351235AP
    2006 Ford F250 Super Duty, 2008 Cummins 6.7, Allison 1000 5spd
    2011 Ford F250 Super Duty, 6.7L Scorpion
    Lifetime Member anarchydiesel's Avatar
    Jun 2011
    you need a base file with security disabled. The options we have for security do not fully disable it. There was a file floating around the forum somewhere that had it all disabled.
    Anarchy Diesel Tuning/ Advanced Injection Diesel Technologies
    EFI Live Cummins Beta Tester
    Duramax and Cummins Tuning
    423-506-7427
    Jul 2012
    Quote Originally Posted by anarchydiesel View Post
    Thanks for the info!
    Anyone out there know where I could find this? How about all of the 6.7 swappers...are you using just the C&C or do you have the LD Ram base file referenced by anarchydiesel?
    Mar 2013
    Quote Originally Posted by beav View Post
    Have you had any luck finding this beav? I am doing basically the same conversion as you and I have tried a number of different files from tunedepot. So much so actually that I am thinking I may have bricked my ecm. The last couple tunes I tried I haven't been able to get it to start at all. Before I could get it to start for the typical 3 seconds. These are my ecm numbers....11610805 61301434.
    Jul 2012
    Quote Originally Posted by 406nick View Post
    I am still using the C&C tune and I have rescaled all of the tables to better match max fueling at 90-100 mm3. It is working pretty well for now with tons of power.
    You probably did not brick your ecu, but probably still just the SKIM issue. After doing the 3 second kill 5 consecutive times, it will no linger start and requires you to disconnect power from the ecu for some time to reset the cycle.
    Dec 2007
    by chance, does this apply to the 5.9 as well? im still having some issues with security after disabling it
    06 Laramie 3500 QC SB 4x4 - Full billet Auto by DTT, HE351/S475 twins, EFI live, lots of custom goodies....
    07 6.2L Yukon Denali - CAI, CAT delete, self tuned with EFI Live
    03 Trailblazer 4.2L I6 - CAI, custom exhaust, EFI live
    2010 Laramie 3500 CC LB 4x4 - H&S, DPF delete, waiting for EFI Live.....
    Jul 2012
    Quote Originally Posted by skneeland View Post
    Why disable SKIM? Are you doing a swap?
    Dec 2007
    no swap, this:
    http://forum.efilive.com/showthread....ing-to-reflash
    truck starts, runs for a few seconds, then dies. dash lit up like Xmas tree & security light flashing. I have security and skim disabled in tune...
    Mar 2013
    So what tune did you end up using (or where did you get it)? I see you are also running an 08 6.7L. Are you using a manual transmission tune or an automatic? I was going to try one that Tobin uploaded but not sure if it will work since it is for an 07 manual. My original ecu is an 08 auto.
    Jul 2012
    I believe that it was post #58 or #59 that i used. Seems like they both worked, but I do not recall which one that I started with. if I had my laptop handy, I could tell you for sure.
    If you are not running a tranny from the ECU, then a manual tune will work fine as long as you are going to modify the tune to some degree because it may not be tuned efficiently for an auto. I want to try running an 08 or 09 O/S for a LD Ram instead of the 07.5 because of the sooting and overheating issues they had in taht year. It is probably resolved with a tune mod, but if it is a problem derived from the O/S, then I would be concerned. As of yet, I am not having any soot build-up issues, but I may not have driven it enough yet.
    Now, with that, i ultimately want to run my Allison from the ECU or at least better integrate true load and defueling between the two via Analog-to-CAN and CAN-to-CAN conversions. The latter, i am already researching and hope to develop a good solution.
  1. SKIM key codes
    By Cummins610 in forum Cummins 5.9L
    Last Post: February 11th, 2013, 05:26 AM
  2. Swapped VZ Holden 1mb PCM - Cruise Control issue
    By krisr in forum Gen III V8 Specific
    Last Post: August 6th, 2012, 09:38 AM
  3. 06-07 cummins engine conversions (skim)
    By crtune in forum Cummins 5.9L
    Last Post: January 23rd, 2012, 04:31 PM
  4. P0633 skim key
    By BSwope in forum Cummins 5.9L
    Last Post: October 24th, 2011, 09:25 AM
  5. Swapped MAFS, now weird issue
    By Dale in forum General (Petrol, Gas, Ethanol)
    Last Post: April 8th, 2008, 04:25 AM
