Results 1 to 6 of 6
Thread: Csp5
    Aug 2011
    Default Csp5
    Hey guy was playing with csp5 building tune when you get to fuel base tables and fuel air density it is in MPa instead of PSI cant copy paste for MPa tops out at 250 so it llat lines all to 250. What all you guys do in this case . Thanks Shannon
    Tuning by Zack StarLite diesel
    Senior Member KhakiCummins's Avatar
    Sep 2011
    Unless CSP5 is different than normal tuning...
    In the menu bar select Edit >> Configure Display Units
    Then Select All >> Imperial and then hit OK.
    That should set all your tables to Imperial Units
    Duane
    2008 Ram 3500 QuadCab
    Hamilton 110# Springs & HD Pushrods, ARP 2000s, EFILive, SB 3250 DD
    Aug 2011
    Thanks that did it.
    Aug 2011
    Have another ? i know units should be imperial so why do all my tunes have MPa vers PSI so do i need to go through all my tunes and config units to imperial. Just dont want to have a prob. when loading ecm. Thanks Shannon
    Senior Member Quinton's Avatar
    Apr 2013
    Default Csp5
    Yes. Select all then imperial
    [/SIGPIC]
    2005 duramax LLY, 12.75 on stock motor/fuel, 68mm vgt built trans.
    Built motor by me, built trans, EFIlive by me, dual fuelers, 80% injectors.
    Aug 2011
    Ok for some reason csp5 was in metric not imperial so change the file i was copy paste metric to match csp5 that caused all my tune to metric thought that was strange.
  1. Csp5 switches
    By cumminsDK in forum Cummins 5.9L
    Last Post: January 22nd, 2013, 05:56 PM
