Results 1 to 5 of 5
Thread: Who Knows...
    Lifetime Member MN C5's Avatar
    Mar 2005
    Default Who Knows...
    What exactly C6302 does? (MAP Sensor Offset) how does this work with C6301?
    Jun 2005
    Check out this thread, D:
    http://efiforum.iqd.co.nz/showthread.php?t=667
    I think Blacky addresses your question in posts 2-7.
    My take is that it doesn't really do anything :P
    Hello, my name is Erik and I am a horsepower addict...
    Mar 2005
    Thanks... a offset factor of 10 just moves scale from 0-100kpa up to 10-110kpa.
    Jun 2005
    Yep -- which leads me to believe that the 0-100kpa map sensor from GM is actually a 10-110kpa. I think it is in the OS so that you can match the MAP sensor's physical behavior to the PCMs expectations (so if you decided to use a different MAP that was physically reading 0-210kpa, you'd set the offset to 0).
    Quote Originally Posted by turboberserker
    No point 'wasting' 10kPa from 0 - 10.
    Most of the maps will cap it to a minimum of 10kPa anyway.
