Results 1 to 10 of 19
Thread: COS3 bootblock error 12212156
    Jun 2010
    Default COS3 bootblock error 12212156
    A little background, its a 98 camaro with a 0411 swap. I just finished the swap and did a full flash with a 12212156 with the fuel segment swap. Started the car up and did the CASE relearn and checked for codes, everything looked good so proceeded to do a full flash of the 02020003 and i keep getting a bootblock error. I also tried COS5 and got the same error, but after the error a can go back and do a full flash of the 12212156 file and it works fine.
    I also updated 7, 8, flash scan bootblock and firmware.
    After doing full flash of 02020003 did you do cal flash from the 12212156 file...?
    ( the full flash you did of 02020003 writes an un-populated file into the PCM, i.e. all the tables/parameters are empty )
    The steps are as follows:
    - full flash 02020003,
    - cal flash from 12212156,
    - read COS file back from PCM,
    - edit COS file to correct B3647 and OOR cells and save COS file,
    - cal flash saved COS file.
    Jun 2010
    After I flashed the 02020003 it would pop up with flash failed. Or is that normal untill I do a cal flash.
    No, "flash failed" is an error...
    can you post the log text that appears during flashing.
    Jun 2010
    19:37:37.531: Scanning for EFILive FlashScan V2 USB
    19:37:37.546: Autodetect interface ...
    19:37:39.781: Interface not detected
    19:37:40.734: Scanning for EFILive FlashScan V2 HAPI
    19:37:40.750: Autodetect interface ...
    19:37:41.031: Interface firmware version: 2.7.45
    19:37:41.031: Connection to [FSV2] interface is OK
    19:37:41.250: USB driver version: 2.8.40
    19:37:41.250: USB library version: 3.2.7
    19:37:41.281: Interface firmware model: FSV2
    19:37:41.296: Interface firmware model: FSV2
    19:37:41.312: Interface firmware version: 2.7.45
    19:37:41.343: Interface firmware date: Jun 08, 2013
    19:37:41.359: FlashScan serial number: 003816159156
    19:37:41.390: FlashScan license number: 003816159156
    19:37:41.421: Disconnecting ...
    19:37:41.828: CAN-VPW Bridge Deactivated
    19:37:41.828: Disconnected
    19:37:42.750: Scanning for EFILive FlashScan V2 USB
    19:37:42.765: Autodetect interface ...
    19:37:44.937: Interface not detected
    19:37:45.890: Scanning for EFILive FlashScan V2 HAPI
    19:37:45.906: Autodetect interface ...
    19:37:46.187: Interface firmware version: 2.7.45
    19:37:46.187: Connection to [FSV2] interface is OK
    19:37:46.203: CAN-VPW Bridge Activated
    19:37:46.281: Current protocol set to: "SAE J1850 VPW"
    19:37:46.281: Autodetect PCM...
    19:37:46.343: Connection to PCM is OK
    19:37:46.359: Current protocol: "SAE J1850 VPW"
    19:37:46.578: USB driver version: 2.8.40
    19:37:46.593: USB library version: 3.2.7
    19:37:46.609: Interface firmware model: FSV2
    19:37:46.625: Interface firmware model: FSV2
    19:37:46.656: Interface firmware version: 2.7.45
    19:37:46.671: Interface firmware date: Jun 08, 2013
    19:37:46.703: FlashScan serial number: 003816159156
    19:37:46.718: FlashScan license number: 003816159156
    19:37:47.031: Getting status...
    19:37:47.062: Status: OK.
    19:37:47.906: Bootloader version: PCM32v1.9F (080A-5B97)
    19:37:47.906: Preparing PCM for reflash...
    19:37:47.953: PCM seed is: $7C32
    19:37:47.953: Unlock attempt 1 of 1
    19:37:48.093: Initializing PCM...
    19:37:48.859: Initializing PCM, step 1 of 4
    19:37:48.859: Initializing PCM, step 2 of 4
    19:37:49.625: Initializing PCM, step 3 of 4
    19:37:51.156: Initializing PCM, step 4 of 4
    19:37:51.593: Initializing bootloader...
    19:37:51.875: Initializing bootloader, step 1 of 5
    19:37:52.281: Initializing bootloader, step 2 of 5
    19:37:52.671: Initializing bootloader, step 3 of 5
    19:37:53.062: Initializing bootloader, step 4 of 5
    19:37:53.453: Initializing bootloader, step 5 of 5
    19:37:53.953: PCM ready for reflashing.
    19:37:53.953: Request VIN...
    19:37:54.015: VIN: 00000000000000000
    19:37:54.750: Request serial number...
    19:37:54.828: Serial number: 2EB3AEGW2171
    19:37:55.796: Request hardware number...
    19:37:55.812: Hardware: 9386530
    19:37:56.312: Request GM CASE[1]...
    19:37:56.328: GM CASE[1]: -2145681428
    19:37:56.453: Request GM CASE[2]...
    19:37:56.468: GM CASE[2]: -2147385347
    19:37:57.375: Intel AB28F400B - 512KB
    19:37:58.203: Erasing PCM flash memory... (please wait up to 120 seconds)
    19:37:58.218: Waiting 1 of a possible 120...
    19:37:59.218: Waiting 2 of a possible 120...
    19:38:00.328: Waiting 3 of a possible 120...
    19:38:00.703: PCM flash memory erased OK
    19:38:00.937: Reflashing PCM's memory...
    19:41:07.515: Total time: 03:06
    19:41:07.515: Data compression achieved: 3.2%
    19:41:07.953: Unknown reply from boot loader: $FE.
    19:41:07.968: PCM is in an unknown state.
    19:41:10.078: Clear emisison related DTCs...
    19:41:11.125: Autodetect interface ...
    19:41:11.390: Interface firmware version: 2.7.45
    19:41:11.390: Connection to [FSV2] interface is OK
    19:41:11.406: Autodetect PCM...
    19:41:11.437: Connection to PCM is OK
    19:41:11.968: Clear DTCs for all modules...
    19:41:13.015: Autodetect interface ...
    19:41:13.281: Interface firmware version: 2.7.45
    19:41:13.281: Connection to [FSV2] interface is OK
    19:41:13.296: Autodetect PCM...
    19:41:13.328: Connection to PCM is OK
    19:41:14.140: Disconnecting ...
    19:41:15.078: CAN-VPW Bridge Deactivated
    19:41:15.078: Disconnected
    19:41:15.562: Reflash failed.
    19:41:18.625: Done!
    I notified Tech Support.
    Jun 2010
    Ok thank you for taking time to help greatly appreciated.
    Also, can you post the COS file that you were flashing.
    Quote Originally Posted by bigblock69 View Post
    After flashing a custom OS the PCM will be left in an "error state" (i.e. what we call dead-poll). That is because a custom OS file does not contain any calibrations and the PCM cannot operate correctly without any calibrations. After the initial custom OS full-flash, you need to perform a cal-flash from a file that contains a valid calibration. I.e. follow the steps Joe posted earlier.
    I'm not sure why the error is being displayed to the end user, but it is expected and normal for that to occur "behind the scenes".
    Ok, understood, these are expected/ok then.
  1. Problem installing COS3 on 12212156
    By overS10ded in forum Custom Operating Systems
    Last Post: May 29th, 2013, 03:27 AM
  2. Replies: 2
    Last Post: May 2nd, 2012, 11:28 AM
  3. Changing OS in 99 C5 to 12212156
    By 02Z06 in forum Gen III V8 Specific
    Last Post: October 16th, 2011, 01:42 PM
  4. Looking for a 12212156 file
    By L31Sleeper in forum Custom Operating Systems
    Last Post: March 31st, 2010, 04:22 PM
  5. COS3 and COS5 lean cruise PE Mode AFR error
    By ringram in forum Custom Operating Systems
    Last Post: August 16th, 2007, 07:25 PM
