Results 1 to 10 of 15
Thread: Windows 8 Flashscan V2 Unresponsive
    Apr 2007
    Default Windows 8 Flashscan V2 Unresponsive
    Hello,
    Helping a friend install everything and flash a tune in. Right now the EFILive control panel says FlashScan is unresponsive and I'm unable to update the firmware or bootblock with this.
    When launching the V8 software it tells me the Flashscan is unresponsive via the popup bubble from the taskbar. I've tried both driver version via the downloads on the website with no luck.
    Any other options?
    2011 Chevy 2500HD LML 4x4 LTZ-Black
    -H&S Mini Maxx | MBRP 5" w/Muffler | 4" Rancho Lift | BMF REPR 20x9 DM | Mickey Thompson ATZ P3's 35/12.50's.
    2012 VW Jetta TDI - Daily Driver.
    SOLD - 06 LBZ
    EcoDieselRam Forum
    Apr 2007
    This is with the V8 software
Name:	efilive error.PNG
    Control panel:
    All software is up to date..
    SOLD - 06 LBZ
    EcoDieselRam Forum
    Apr 2007
    Now, on the EFI Control Panel, it actually showed connected for a moment, took the boot block update and now proceed to restart after the Firmware update was finished, once it restarted it was like nothing ever happen.
    SOLD - 06 LBZ
    EcoDieselRam Forum
    Aug 2010
    Nice to hear you got it sorted out with Windows 8. Just got a new Notebook recently myself. Got rid of Windows 8, and loaded Windows 7 Professional instead.
    Apr 2007
    Looks like we have bigger problems. Everything shows green, arrows, etc for the USB Connections, we downloaded the stock tune with no problem. Now, went to Full Flash the DSP5 setup and it stopped mid way. With No Data Received. Try to Flash it again and we have this.
    Truck will not start.. :(
    Removed EFILive and reinstalled and same problem.
    Truck is a 2008 Duramax LMM
    SOLD - 06 LBZ
    EcoDieselRam Forum
    Aug 2010
    Have never tuned a diesel ... no idea how their controllers work.
    Here is a PDF of V2 and AutoCal error codes ... not sure if it will be of any help.
    Apr 2007
    Thank you, yes the error: Conditions Not Correct or Request Sequence Error ($22) is what we are getting.
    I'm having him unplug the batterys tonight and I'm driving up in the morning with my PC and see what happens. I flashed a friends LMM a couple of months ago with no issues so I know my software is ok..
    Anyone else have ideas? I'm not coming up with much on a search.
    SOLD - 06 LBZ
    EcoDieselRam Forum
    Aug 2010
    Believe there was also a $0322 error on the screen shot ... looking that up, I believe indicated to try again, and contact support if persistent.
    Apr 2007
    So after a fresh start today. Here are my steps..
    1. Uninstalled V7 & V8. Rebooted PC and reinstalled .
    2. Successfully Full Flashed the stock tune after the truck was in a no start condition. Truck starts with the stock tune, back at square one.
    3. Loaded the Modified file sent from tuner in V8, it goes 2:52 minutes into it and has the error as the screenshot in post # 5. Truck will not start again..
    **I also created a modified file from his stock with DPF off thinking it was a bad file but it also would not take**
    4. I put the ECM on a bench harness and FINALLY got the stock tune to flash in. I did try to flash the Modified tune on the bench but it still would not take.
    5. I tried every combination possible with the V2 and even used my PC to try and flash with no luck. I then went to do BBX flashing and I get a communication error (I'll post screenshots later) with the V2 and my pc and my friends PC when trying to update the BBX settings.
    After all of these steps failed I bought a license for my V2 and and proceeded the flash the tune fine with his PC, I even done BBX Flashing with my V2 on his truck to rule out everything.
    Now I've come to the conclusion that the V2 (new blue one, bought from SoCal diesel) is not functioning 100%, each time I tried to FLASH a tune it fails, or each time I go to update via the BBX settings it has communication errors and fails..
    Now I've had to waste a license on my V2 because of the busted one. I'm running the 100% latest version of EFILive on my PC (Windows 7) and my friends (Windows 8). Firmware and Bootblock is also up to date on both V2's.
    Truck is running great now after flashing with my V2 and the file the tuner sent that would not load with Windows 7 & 8 via the blue V2.
    SOLD - 06 LBZ
    EcoDieselRam Forum
    Quote Originally Posted by 8100 Power View Post
    That should not happen.
    Can you try updating the BBX settings again and after the error occurs, open the EFILive Control Panel (by clicking on the FlashScan icon in the System Tray near the clock on the Windows Task Bar).
    Then select the [F8: Trace] tab page and click on [Save Trace]. Then send that trace file to me (at paul@efilive.com).
    Include a link to this thread so I know what the file is for.
  1. Any tips for recovering unresponsive roadrunner.
    By johnv in forum RoadRunner Real-Time PCM Emulator
    Last Post: September 5th, 2014, 01:45 PM
  2. V2 keypad very slow or unresponsive
    By Highlander in forum FlashScan V2
    Last Post: March 26th, 2013, 05:31 AM
  3. Help V2 Buttons/Screen very slow and unresponsive
    By rcr1978 in forum FlashScan V2
    Last Post: April 13th, 2012, 03:55 AM
  4. Windows 7
    By Chevy366 in forum Lounge
    Last Post: November 13th, 2009, 07:34 AM
