Anyone done this? Tried? have any ideas to do this?
What would be cool is to have the GPS output a standard serial format and run that into the RS232 port on the FSV2....
I meant in the situation of finding a lost or stolen one, but this could be a nice idea too. Although I see the Harry's Lap Timer a better option for what you want to do.
So you'd need the following.....
- Mini GPS unit with mobile data sim card option.
- Power supply
There's a little bit of room inside the case to do this and I've thought about just adding a 3.7V Li-Ion battery cell so I don;t have to keep resetting the time on the V2. With a bit of tricky wiring, you could charge the cell off the USB / OBD-II power and it would charge every time it's plugged in.
The cheaper option is to add your phone number and a "reward if found message" to the splash screen.
Simon
Check out the Fleece data logger, it has lots of input channels, GPS, accelerometer and integrates with V2 through the serial port.
