Results 1 to 4 of 4
Thread: dsp5 issue with autocal
    Jul 2013
    Angry dsp5 issue with autocal
    Im having a issue with the dsp5 switch ive check the holes the pins needed to in and made sure they where all the way in and also checked the switch it self and made sure the washer was in the right hole. ive tryed to load my tunes on to the truck and the only tune that is works is my big tune anyone know why my other tunes aint loading or working
    Lifetime Member comnrailpwr's Avatar
    Jun 2011
    Default Re: dsp5 issue with autocal
    New problem? New switch? Was it working before? Do you have it set to hardwired and not serial in your tunefile? Efilive custom Calibrations tab. I think its the first tab.
    Apr 2008
    also check in the dsp tune that you have the voltage set (ie tune#1 = 4.0 volts)
    stock sucks
    Jul 2013
    I don't have a volt meter to check and under efilive 7.5 scan the pids and the dsp5 volt then tryed to go to data and record and it kept showing a error that more than one pid was selected and didnt see any other that was
  1. DSP5 issue
    By Jon in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 16th, 2012, 04:15 AM
  2. dsp5 reflash w/o having orginal os or current dsp5 os
    By relentless addiction in forum General (Diesel)
    Last Post: July 12th, 2012, 04:55 AM
  3. Replies: 0
    Last Post: February 8th, 2012, 06:56 AM
  4. dsp5 voltage issue..
    By Dmaxink in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: April 11th, 2011, 02:31 PM
  5. Lmm dsp5 issue!
    By cumminsDK in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: September 7th, 2010, 11:47 AM
