Attachment 15612Attachment 15613here are the last 2 done
Disregard 22 and 23 as they were changed today.
Last edited by warlock007; July 30th, 2013 at 11:29 AM. Reason: added updated logs
Hi Mike,
Your OS 12584929 does not support the pid GM.DYNAIRTMP_DMA...
so you will need the alternate calc_pids.txt file, see post #1 Appendix item #6 here: Calc.VET Thread
you will need to check that CLC-00-260 in the calc_pids.txt file contains the same data as your B4901 table.
you will need the B4901 and DAT pids...
so do this:
- remove these pids: AFR, ASPARK, MANVAC, SHRTFT1, SHRTFT2;
- add these pids: WO2LAM1, WO2BEN, LTFTBEN, SELBEN, B4901, DAT, CL;
(this should bring your pid channel count to 24, look at bottom of PID tab)
and capture a new log.
I dont understand what to do and where, the last time i tried to copy a text file i lost all my maps.
WO2LAM1 is for a LM1 analog isnt it? I have a LM2 serial connected WB
Ok, I figure out how to add, I removed AFR(anything that said it).
I was able to add lam1, ben, lTFTben, B4901 but dont see SelBen, Whats DAT, CL. without SELBEN DAT AND CL count is 23
SELBEN, WO2BEN are calc pids from the alternate calc_pids.txt file...
