Results 1 to 10 of 14
Thread: Even I figured out the AutoVE
    Jun 2003
    Default Even I figured out the AutoVE
    After finally breaking down and getting an LC-1 WB02 from greenlightmotorsports I went through the whole setup of the maps and tunes. Not as hard as I thought it was going to be.
    Pretty amazed at how rich this was running, before doing the autove I was just checking how close I was with the ltft method and what the afr was showing. -5 to +5 was more like 12s AFR :|
    After a couple more runs the BE should be almost dead on the 1s
    Now to just make a quick connect so I can use the LC-1 in the SS and GTO a lot quicker.
    If I got it working anyone can
    Jul 2005
    Every car I do gets a 18x1.5mm nut welded into the exhaust so I can fit my WB.
    The actual unit has a cigarette lighter fitting so I can plug it into the cigar lighter.
    \"You Can Never Have Enough Horsepower\"
    Yes a wideband (or two) is worth the money, reveals what is really going on.
    Jun 2003
    Quote Originally Posted by caver
    That sounds pretty neat. Dont need to do any welding, both my cars have LTHeaders so I just use the passenger side front o2 for the wb sensor. Then put back the other when i am done.
    I am just lazy and want to be able to put the wb on if I am hitting the track and depending on which car I take so if I want to do some quick tweeking I can.
    ... so LS1 PCM's don't care if one of the stock 02's is removed (pre cat of course).
    - Marshall | http://www.performancemotorsports.com | Dyno Dynamics in the house!
    Jul 2005
    I am even lazier dont want to waste time unscrewing the std o2 sensor.
    foff667
    Guest
    Quote Originally Posted by mmorgan24
    if your running in open loop no it doesnt care.
    You can setup the WB to simulate the NBO2 if you want closed loop.
    Jun 2003
    Hunting down an old radar detector cigarette lighter connection now
    Or hit a walmart and pickup one on the way home. Great idea.
    Junior Member Jphdg's Avatar
    Apr 2006
    If welding in a widband O2 bung, it obviously sounds like it does not matter if its installed on one bank or on the other?
    I run a duel exhaust (two cats, one NB on each bank) and had not been sure if the two banks can differ in AFRs while trying to tune them. Is that why they normally use two NB 02's for closed loop to keep tabs on this?
    If both banks do differ, is it by much, hence could this cause a leaner or richer condition on the bank not being monitored by the wideband O2?
    I hope I made sense...
    BTW my first post here and a great site this is
  1. Replies: 32
    Last Post: June 24th, 2010, 06:21 AM
  2. Has anyone figured out LC1 NB simulation?
    By SSpdDmon in forum General
    Last Post: September 7th, 2009, 06:55 AM
  3. AutoVE done.....what next?
    By Happy Jim in forum General (Petrol, Gas, Ethanol)
    Last Post: May 29th, 2009, 09:48 AM
  4. I figured out how the pcm works...
    By joecar in forum Lounge
    Last Post: June 24th, 2006, 06:58 AM
  5. figured out why my mouse dont work
    By wait4me in forum Lounge
    Last Post: December 11th, 2005, 08:46 AM
